2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Gmpp clutch for the 2.2?
Old Aug 27, 2016 | 06:14 AM
Kozybe's Avatar
Just recently supercharged the 2.2 and its slipping. Just wondering if anyone knew if the gmpp clutch will work with my 2.2?
Old Aug 27, 2016 | 08:14 AM
Sl0wbaltSS's Avatar
Only works on LNF/LSJ sorry. teeth count are different.
Old Aug 27, 2016 | 02:32 PM
Kozybe's Avatar
Ok thanks for the info
Old Aug 27, 2016 | 02:41 PM
Kozybe's Avatar
I'm a little confused actually. I was looking at the ZZP 2.2/2.4 9.5" clutch as well. The description says it will work for a f23 or f35 trans. Isn't lnf the f35? If it is how can the lnf (f35 trans) and the lsj be the same? If ZZP's 9.5" clutch works for both does that mean that all clutches are interchangeable between the two transmissions (f23 & f35)?
Old Aug 27, 2016 | 03:00 PM
DFZ24's Avatar
I know kinda misleading information.
But if I'm not mistaken, that is a custom clutch kit, and is compatible with both transmissions.
Old Aug 28, 2016 | 02:23 PM
Kozybe's Avatar
Has anyone heard any good things about the ZZP 2.2/2.4 9.5" clutch? Or does anyone recommend a certain brand? I'm trying to research the best clutch for my application (supercharged 2.2 w/3.1 pulley and f23 trans) and it seems that everyone's post has a different opinion on all the different clutches. Thanks in advance for the replies.
stormtrooperxl
Sep 18, 2016 08:02 PM
Gugi96
Aug 27, 2016 05:02 PM
bigez96
Aug 24, 2016 01:32 PM
cjdz24_Z28
Aug 16, 2016 06:21 PM
beast124
Aug 15, 2016 05:51 PM
