2.4 supercharged guys
Hey guys, I am looking to buy a supercharger kit (maybe the one bluebolt66 has). How did you guys tune your computer? I will have to drive 10 hours to his town to get it and for him to help me install it. He doesnt know if hptuners has the 2.4 unlocked or something like that. How did you guys get yours tuned. Also what injectors should I use? The kit doesnt have injectors so I want to have everything I need before I drive 10 hours. Any help or tips would be great, thanks guys.
i run with the gm stage 2 pulley with the 42's injectors, im tuned by trifecta if you have the stock pulley you can run on the stock lsj injectors and i have these injectors if you want
i would do this at your house, why drive 10 hours then get stuck and not be able to finish it, go with ev6 60lb injectors since u can use them in your stock harness, and a 3" pulley, ull be happy
you can get trifecta to tune your car but that can be a pita also, make sure you have everything , and do your research before you start tearing things apart, intake manifold bolts and lower intake manifold / intercooler pump bolts are different then the LSJ so they will not work, and hardware stores that carry a wide range of metric rod and bolts are few and far between at least around here that is
good luck
ps, HPT tuners will work for your car, its $100 dollars for the credits towards your car
good luck
The guy want $250 to tune mine. There are several kits on here but i think bluebolts is probably the most complete. If anyone knows of a complete one. Let me know. Also, I know nothing about switching a supercharger thats why I was driving to get him to install it. If it were an old school v8, I would have no problem.
z28addiction
09-28-2015 12:03 AM
roth
09-26-2015 12:16 PM
