lsj air to air problem
Old 06-24-2009, 12:42 PM
  #151
ebristol's Avatar
Originally Posted by Omega_5
Freakta, STS2/SS... keep on doing what your doing....
I don't see what is so impressive about 286whp on a TVS. That is what I made on the stock IM.
Either way, what I'm wondering is; are your comments directed to the fact that they used the OEM manifold?
For me yes. If I got a new one then that would be the best design. jk
I agree we should hold off on the flaming until all the results are in. Those IAT2 temps are pretty impressive.
Old 06-24-2009, 12:55 PM
  #152
Maxim_X's Avatar
The impressive thing is, he just ran a base tune with no timing to get AFR strait. And, it was only running 14psi.
Old 06-24-2009, 01:38 PM
  #153
freakta's Avatar
and no meth
Old 06-24-2009, 02:19 PM
  #154
Omega_5's Avatar
Your overlooking the other details, as pointed out by Maxim_X.
Old 06-24-2009, 02:40 PM
  #155
ebristol's Avatar
As in "no timing"? What does that mean exactly? How many degrees? You can't amp up the timing on a TVS without meth injection or racing gas anyway.
And 14psi? I would really like to know the theory behind this. This is on a stock head right?
Correct me if I am wrong but the Map sensor on the IM is after the laminova cores. So it is reading the pressure between the exit of the laminova cores and the head. At that point in the IM the main restriction is the inlet ports on the head.
How much timing?
Old 06-24-2009, 02:43 PM
  #156
slowswap's Avatar
I stand by what I said earlier, this air to air setup vs proper cooling mods is not going to yield much better numbers if any at all.
Old 06-24-2009, 03:11 PM
  #157
Omega_5's Avatar
That's a common misconception. The guys that commented on porting the stock manifold said the same thing; that the pressure would rise, not drop. When really, the manifold pressure would indeed drop due to a higher flow.
I know it's a hard concept to grasp... but remember, it's a dynamic system... not a static system.
Old 06-24-2009, 03:43 PM
  #158
ebristol's Avatar
Maybe I don't understand this pressure and restriction stuff that well.
Let me ask a simple question just to make sure I understand.
Old 06-24-2009, 04:14 PM
  #159
Omega_5's Avatar
Neither.
Your missing half of the system on those diagrams.
Edit:
PM me on the other site, I'll explain more there.
Old 06-24-2009, 04:30 PM
  #160
ebristol's Avatar
Neither.
I left them out intentionally. Imagine a blower bolted to the left side and the head on the other. Same amount of output from the blower. Same amount of restriction from the head.
ok.
Old 06-24-2009, 05:09 PM
  #161
mrbelvedere's Avatar
omega would you explain it here also i would like to read about it also
Old 06-24-2009, 05:16 PM
  #162
slowswap's Avatar
Pressure shouldn't drop, air flow velocity should drop. The supercharger is always making 12 psi. Doesn't matter size of charge piping or manifold design. Pressure won't change. At best, a small decrease from being cooled. In at a water to air setup, .1 psi.
Old 06-24-2009, 05:45 PM
  #163
Maxim_X's Avatar
Many people see pressure drop in a a2a intercooler setup.
Regardless his psi is low because of the ported head.
By no timing I mean they are probably around 16-15 advance instead of where he is going to be meth. He should see as high as 25 advance with his direct port meth setup.
Old 06-24-2009, 06:04 PM
  #164
Omega_5's Avatar
What?
Airflow is going to drop if you provide less of a restriction? Is that what your trying to say?
I think you missed out on a flow dynamics course somewhere....
BTW... your still assuming it's a static system... think dynamic.
Anyways... I'm off to go camping... hopefully within the next 5 days someone around here figures out how flow dynamics work.
Old 06-24-2009, 06:24 PM
  #165
STS2/SS's Avatar
This is crazy! Freakta has a ported head and a realy efficient intercooler I benched his head and flowed it as well as built the manifold. The bottom line is it's flowing 40% more mass/volume/air at .240 inches of lift, then he was origanly just from the ported head, his luminovas where so increadibly clogged from all of the oil vapor coming from the emmisions that the designed needed to be changed so now he runs a special pcv system that can handle boost. The stock pcv valve just burps oil into the manifold every time you boost up, which is killing your power over time. Everyone can vouch for this; get new parts pulley, injectors and such then you get it tuned you make 260ish. In 6 months to a year you go dyno your car again all the sudden your making 190-220ish hummmm wonder why? The whole point of this discusion is this the stock manifold is a piece of ****!!!!!!! I don't care if mine doesn't make a hundred more horse power or whatever the fact is you wont be robing your self of horse power over time and you have colder AIT2 which means denser air which means less boost to make more power which equals SAFE!!!
Old 06-24-2009, 06:53 PM
  #166
how do you build a boost friendly pcv system
Old 06-24-2009, 07:52 PM
  #167
STS2/SS's Avatar
I cant tell you everything cause then everyone would build one.... I can say it's from an
OBD 1 vehichle..., hahahahah. No I use the PCV for a slant nose porsche turbo that wont burp oil into the manifold. You also have to tap the head where the stock PCV butted up to, to except a barbed fitting. It was trial and error, I know this you cant just build an intake manifold if you don't know anything about these cars..
Old 06-25-2009, 10:48 AM
  #168
Tennpenn83's Avatar
Originally Posted by freakta
and no meth
i don't get it.. i ran a base tune on my tvs setup, made 285whp and got flamed by zoomer because i didn't hit over 300. my original tune was very rich, and had very conservative timing as well. if you saw my thread, you would probably agree that there is much to be had in a retune. stock intake manifold with dual-pass/opt B/heat exchanger and boostin 19-20 psi
now, freakta, don't get me wrong. i am glad that you are looking into this and have made progress. it's only my opinion that it would probably not be worth the cost/benefit ratio - at least to me. but keep up the good work, and keep the thread updated.
Old 06-25-2009, 11:20 AM
  #169
slowswap's Avatar
Thank you. I'm interested to see the final graph but I think the stock intake manifold with proper cooling mods can handle the job. This just ruins all flow.
Old 06-25-2009, 02:13 PM
  #170
IonNinja's Avatar
I'm confused lol...how does this setup go TVS > FMIC > IM > Head?
Any pics of the stock IM off the head? I'm not understanding where the drivers side pipe runs to. It looks like they both run to the bottom of the IM?
Old 06-25-2009, 08:21 PM
  #171
HunterKiller89's Avatar
they probably do. the half of the IM closest to the front of the car has a pipe coming out of it, so air that would just be entering the IM in a stock setup is instead now leaving the IM (pre-laminova cores) and going through the FMIC. After that, it re-enters the back half of the IM (post laminova cores) and through the ports to the head.
At least, this is how i understand it.
Old 06-25-2009, 08:34 PM
  #172
IonNinja's Avatar
Ahhh so the front portion of the intake mani is blocked off from the back...didnt know that. guess I'm an IM noob
makes alot more sense that way
Old 06-25-2009, 08:38 PM
  #173
STS2/SS's Avatar
It gets rid of the small pulley heat soak issues, that I know. I'm a geniuss, hahahahahha!
Old 06-25-2009, 08:45 PM
  #174
freakta's Avatar
pretty much it, just no laminovas in there to hold things up
Old 06-25-2009, 09:23 PM
  #175
STS2/SS's Avatar
^^^Yah!^^^^
Quick Reply: lsj air to air problem
