Plasti-Dip Issues
Old 05-04-2013, 08:14 AM
PyroSiege's Avatar
Plasti-Dip Issues
Has anyone had problems with certain cans of Plasti-dip?
I have had some major success with Plasti-dip,I painted my wheels, grill, etc... (all with black) and it all turned out great with no issues.
The other day I decided to try the new Blaze Orange stuff. The first thing I noticed was that the tip was different. Instead of the smaller cylindrical tip, it had the bigger button style tip (I'm assuming it's more ergonomic or something). I thought it would be a good thing. However, after the second coat, it started coming out kinda clumpy and bubbly, and not a fine mist like i was used to. This caused the latter coats to start drying with small holes in the paint (like bubbles imploding) and it was much more uneven. I tried shaking the can more and it didn't seem to help, it just got almost foamy.
I have bought a few cans since, and it seems like it only happens to the cans that have the bigger tip on them. The can of black Plasti-dip comes out perfect every time and it has the more traditional tip. I don't get it...
Is it a temperature thing? maybe those cans don't work well cold? Can you switch the tips of the cans?
This is pretty frustrating right now. I want to paint something with the white and orange plasti-dip but they are both doing the same thing.
Old 05-04-2013, 08:19 AM
turbosmart4's Avatar
Switch the tips and see what the outcome is
Old 05-04-2013, 08:25 AM
breds2k's Avatar
The cans should be 60-70+ degrees to spray correctly.
Its is 100% a temperature thing. Even when its 60 degrees out i had a little trouble spray the other day, threw the cans in a tub of hot water, warmed them up and they worked perfect. And do youself a favor and order the wide spray tips from Dipyourcar they are an amazing difference.
Old 05-05-2013, 03:56 PM
Josh-SS's Avatar
Heat the cans with a blow dryer for a misty spray. Make sure the dips are clean. Make sure to keep a consistent spray pattern.
Old 05-05-2013, 03:57 PM
GoodLuckBro's Avatar
Kiss the tip. No homo.
Old 05-05-2013, 08:51 PM
Tcobalt421's Avatar
id have to agree with everyone else, while the tip your talking about may spray a bit different, its all a temperature issue with the cans. I suggest you spray in 60 degree plus weather, and if you cant use the suggestions above, i personally wouldn't use a hair dryer, but the warm bath of warm glass that the cans can sit in for a sec will fix that issude right up,good luck
Old 05-05-2013, 09:17 PM
breds2k's Avatar
turn your defrost on high heat and throw the cans on the dash, works great. I plastidipped in a garage about 40 degrees with no problems.
Old 05-14-2013, 05:31 AM
PyroSiege's Avatar
Thanks for the tips guys. I put the can that was giving me issues in warm water for a bit and it seemed to spray much nicer. as soon as it cooled off just a bit it was back to spraying crappily. Gotta keep em good and warm I guess, heh.
Trav3480
10-01-2015 08:17 PM
Tupp
09-30-2015 08:18 PM
yellow dragon
09-28-2015 09:49 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: Plasti-Dip Issues
