Borg Warner 257
#102
If somebody wasn't out of coil packs my powerband would be getting a major overhaul next week
#103
I looked at that video again and noticed that with the 4.45 gears it hits 60 around 4100rpm and starts screaming at 4500 with full boost so that's not much time waiting for spool.
I think Zack and I should have simular results with our 7163 and 4.05s
#106
Truth
#109
So finished Justin's tune today 24.3psi @ 24* timing with a 60 to 100 of 3.505!!
I'm really happy with the results and the turbo spools faster than I thought it would. I had to work a lot with the fuelling on spool to keep the rail pressure up. So I would recommend at least running a fuel lobe with this turbo to keep up with the spool we're at 6.4ms up top @ 24psi so we have more headroom there but we would also have to switch out the 14psi WG spring to the higher rate one he has.
Justin is planning on hitting the dyno his next day off so I can't wait to see the numbers!!
#111
So Justin had a tach fail like usual but made 481hp on 24 to 25psi which is bad ass on a stock engine!!!
#116
Oh trust me Justin wants to race! And you know me I'm game to line up anytime!! Yes it's ironic we again both dynoed basically the same on the same boost (25psi) him with a bigger turbo me with better flow
#117
I just talked to Justin he wants to race but with my new job it has to be next year. I have a trip planned already
#118
So justin wants to turn his car up but is maxed on fuel on both spool and topend. So we are going to try E35 and a spring change to get the boost up.
#120
Wow really?? I did 511 on 27psi with a 7163
#123
So we finished Justins E35 tune tonight. He says it's way faster and we got more spool and boost and were still able to run the same timing!! I think he's over 500hp now
#125
