LNF 2.0 coolant drain
Old 08-18-2015, 09:53 PM
stevehendo34's Avatar
So I searched for this but everything for supercharged engine any steps.
Old 08-18-2015, 10:12 PM
kzak104's Avatar
one on the rad one on the back of the water pump.
Old 08-18-2015, 11:10 PM
where is water pump?
Where is drane on radiator
Old 08-18-2015, 11:29 PM
exninja's Avatar
The water pump is on the back of the engine. It has a huge tube coming out of it. Can't miss it.
The radiator drain is on the bottom of the radiator. Passenger side I believe. Can't miss it.
Old 08-19-2015, 03:16 AM
How do you get to back of the water pump from under the car?
Where is this drain on water pump anyone have pics
Old 08-19-2015, 11:47 AM
Kolt's Avatar
Radiator drain is on the right side
water pump drain
Old 08-19-2015, 12:00 PM
blueLNFftw's Avatar
If you hit a raccoon it will drain itself for you.
Old 08-20-2015, 12:34 AM
"water pump drain location"
Hell with it I removed radiator plug drained it filled it with water from over flow tank 3 times until it ran clean and filled coolant and distilled water from overflow tank. Burped like that refill video said to do on the hose little hose across the top of the engine until coolant squirted out.
Running 176 degrees to 184 176 degrees. cooler when driving faster.
Old 08-20-2015, 12:42 AM
"hit a raccoon"
Take out you intercooler first--Why the hell did they hang them so low--snow plow I guess?
Badgers in Wisconsin
Old 08-20-2015, 07:00 AM
LNFTX's Avatar
Be prepared that drain on the lnf radiator is very difficult to get to, had to remove the intercooler piping and unbolt the intercooler to get to it.
Hell it was the hardest part of replacing the radiator for me.
Old 08-20-2015, 10:02 AM
blueLNFftw's Avatar
F that.
I would have just pulled the lower hose off lol.
I do all I can to avoid breaking open the charge pipes on the LNF. One crack and its leak chasing for days it seems lol
Old 08-21-2015, 05:13 AM
Fist clip on inner fender plastic. Taped it open wit Lon screw drive a bit. Reached in with fingers and spun it off.5 min total. Hose LOL
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
HEATON
10-16-2015 07:21 PM
10-13-2015 09:32 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: LNF 2.0 coolant drain
