All Engines: Fuel Filter Change How-To with pictures
Old 04-26-2010, 11:16 AM
  #251
rnjmur's Avatar
Originally Posted by rallyracer
Make sure u have the 3/8 disconnect tool all the way into the filter...that's was hard for me so I had to use both hands. Reached around so I could grab the tool with my finger tips (both hand) and use my thumbs to push down on the other end (2 fuel line end).
I pulled the tool in as hard as I could. Then used one hand and started spinning the filter in up and down while pulling to the right at the same time....finally after doing that it came off.
Note- I took the screw out the holds the filter onto the car.
I hope this makes sense...I'm writing this on my iPhone while at work.
I agree, it can be a pain to get off if the prongs are a little bent.
Originally Posted by silver187666
what did your prongs look like?
and its on there tied you just got to pull harder
When I got my filter off the first time it was ok, but the second and third times I changed it the prongs were bent pretty good and it took a bit of muscle to get them off.
Old 05-20-2010, 01:50 AM
  #252
bigdogstokes16's Avatar
i went to advance today to look for a fuel filter and he tried to tell me he cant get a fuel filter for my car then he tried telling me i dont even have one WTF? and ive got 36k on the stock one, the car stutters pretty good sometimes too
Old 05-20-2010, 10:10 AM
  #253
rnjmur's Avatar
If you look under the car in the back and can see the fuel filter, then it is the same filter that all the other cobalts use.
Old 05-22-2010, 02:51 AM
  #254
i looked under the car right where the post says and theres no fuel filter there
Old 05-22-2010, 02:57 AM
  #255
rnjmur's Avatar
The fuel filter is part of the fuel pump in that case.
Old 05-22-2010, 04:50 AM
  #256
so therefore is not easily replacable?
Old 05-22-2010, 12:09 PM
  #257
rnjmur's Avatar
Yes, it is non servicable. You have to replace the entire fuel pump assembly which is a bit costly.
Old 05-22-2010, 01:05 PM
  #258
rallyracer's Avatar
I think around 100K or so Im just gonna do the fuel pump....I've done the filter but im sure around 100k it'll be time for new pump.
Old 07-04-2010, 03:48 PM
  #259
hoop's Avatar
thanks for this tutorial! saved myself 80$ vs. the stealership...
Everything went smoothly except the first quick disconnect tool I bought wasn't manufactured well. The 3/8'' side on it didn't come close to fitting...
Old 07-04-2010, 08:18 PM
  #260
outtamymind's Avatar
the fuel filter is behind the big black box hidden up a little bit. you need to get right under the vehicle to see it.
and the only cobalt that has an internal fuel filter is the TC so in your case yes it is part of the fuel pump
Old 07-09-2010, 09:48 PM
  #261
trey ss's Avatar
sub'd
Old 07-11-2010, 01:07 AM
  #262
silver187666's Avatar
thats false. tank07(think thats it) only just got a SS and his didnt have a filter either
Old 07-11-2010, 01:39 AM
  #263
unless they changed them for 09 sports and lt's then they would still have a fuel filter. as far as i was aware they still had an external filter. the only one that changed was the TC and from my guess its because its DI and the filter is part of the fuel pump which is in the tank.
Old 07-15-2010, 09:35 AM
  #264
Axelthered05's Avatar
Originally Posted by silverSS
gm recommends 30
oh snap im at 50k beter get on that lol
Old 08-01-2010, 04:26 PM
  #265
SJL26's Avatar
So the quick disconnect tool everyone used was 3/8" ? I plan on buying the metal one and not the plastic set.
Old 08-05-2010, 07:18 PM
  #266
kkanowitz's Avatar
For the record guys, my 2007 LS doesn't seem to have a fuel filter either. I searched around CSS.net, and it seems that quite a few of the 07s don't have them. I'm guessing there's a screen in the fuel pump.
So yeah...that guy wasn't the only one.
Old 08-05-2010, 07:32 PM
  #267
rallyracer's Avatar
Yep! 3/8 is the right size....I should know since I ended up buying the wrong kit that had every size but 3/8
Old 08-05-2010, 07:35 PM
  #268
davis9's Avatar
yup same here im a 07 2.2 g5 and have no visible fuel pump..
Old 08-26-2010, 06:26 PM
  #269
deuce's Avatar
has anyone found it for less than 50 bucks? (crateenginedepot)
gmpartsdirect has is for 35 but it automatically adds 12 in a pack..
Old 08-27-2010, 11:17 AM
  #270
csementuh's Avatar
There is a filter that works at AutoZone. I think its a Luberfiner..
Have it on two Balts...
Old 08-27-2010, 12:07 PM
  #271
SS Pyro IV's Avatar
my local dealer wants 72 per filter...
Old 08-27-2010, 04:07 PM
  #272
csementuh's Avatar
Grab the Autozone filter if you can. Same damn thing, and prolly better quality...
Old 08-27-2010, 04:25 PM
  #273
SS Pyro IV's Avatar
i hit up a buddy at another dealer and he can get it to me for like 44. and the kid at autozone kept arguing that my car was a 2.2 and not a 2.0 because its supercharged....
Old 08-27-2010, 04:29 PM
  #274
csementuh's Avatar
Haha what a toolbag.. They're all the same filter though, so it doesn't matter... All of them are the same unless its a newer Sport or SS/TC because in those years the filter was moved into the tank..
I have the Autozone Luberfiner filter on my 07' SS/SC and my GF's 08' LT.
Old 08-27-2010, 06:54 PM
  #275
deuce's Avatar
just did this, i bought a metal tool from auto zone but had to file it down to fit right, damn cheap china parts
Quick Reply: All Engines: Fuel Filter Change How-To with pictures
