Nitrous Oxide N20
Stage 3 PCM Nitrous Wiring Diagram
Old 09-28-2008, 10:24 PM
creepySS's Avatar
Have someone has better instructions on the wiring,using the colors from the relay harness plug .Those from gm are a little bit confusing, and my doubt is with the green wire coming off the relay harness. does it go to ground or to the input of the pcm?
Old 09-28-2008, 11:12 PM
Negrita SS's Avatar
From What I Under Stand The Green Wire Is Ground From The Pcm I Hook Up The Green Wire To The Pcm J3 For Got What Number Pin It Is. But If You Look At The Realy And The Wire Diagram It Show You Its The Ground Of The Relay Im Using The Nos System Ill Take Some Pics And Post It Tomorrow
Old 09-28-2008, 11:30 PM
creepySS's Avatar
this is what i got, correct any mistakes.i think #3 is the correct one
when i get the kit ill do an how to for everybody with pics and diagrams.
DarrenGC
12-24-2021 01:55 PM
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
dennis69
10-20-2015 07:39 AM
ernnyyes
10-02-2015 05:16 PM
jmelton327
09-26-2015 10:04 PM
Quick Reply: Stage 3 PCM Nitrous Wiring Diagram
