Battery reset: radio still remembers station presets
Hey I'm trying to get cruise control working after replacing the led 3rd brake light with normal bulbs. I figured I'd reset the battery before moving on to replacing other things like clutch switch and cruise switch. I'll remove positive and negative terminals overnight then reconnect them and come to find the radio still keeps its presets and clock. Is is actually resetting? Thanks
Heh nah I noticed it does reset the time so it is resetting. Has anyone ever fixed cruise by fixing turn signal lever?
https://www.cobaltss.net/forums/2-0l...0/#post5778030
Mine doesn't work so I'll start with what I know is broke before the shotgun approach of throwing $ at all other possibilities...
my cruise sometimes doesn't work, when I take the battery out for a while, or when I for some reason turn the car off and back on while driving lol don't ask. then I have to play with the button a bit and basically just leave it alone after that then It starts working
I went an tested my switch contact points today and got open loop with switch engaged so hopefully a new switch is all I need!
