cruise control not working
Old May 12, 2011 | 10:35 PM
paintballerr78's Avatar
Like title says 2010 lnf 16000 miles my cruise does not work tried pulling up on clutch doesn't work
Old May 12, 2011 | 10:37 PM
Chevycobaltss3's Avatar
clutch b ircuit possibly, take the ecm connectors off for 10 mins and restart the car and all should be good to go!!
Old May 12, 2011 | 10:40 PM
BlackARCA06's Avatar
Warranty?
Old May 12, 2011 | 11:22 PM
tomj77's Avatar
minw stopped one time but it started working again, try pulling battery off then back on see if it helps if not, warrenty
Old May 12, 2011 | 11:24 PM
LS6Rally's Avatar
Check your 3rd brake light, a bulb out will cause the CC not to work. and your Clutch Top of Travel switch.
Old May 13, 2011 | 12:39 AM
Fastgti69's Avatar
Originally Posted by BlackARCA06
Warranty?
x1231432 warranty, end of story.
Old May 13, 2011 | 12:43 AM
chood711's Avatar
mine stopped working due to me resting my foot on the clutch. it may be that.
Old May 13, 2011 | 08:43 AM
Grishbok's Avatar
.....what....the....@#%^? Please cease this activity immediately. Your foot should not be on the clutch unless your engaging/disengaging it.
Old May 13, 2011 | 12:21 PM
vanillathrilla's Avatar
This happened to me on my SS/SC, needed a new signal lever
Old May 13, 2011 | 01:30 PM
sponge14's Avatar
Happened to me once, shutting the car of and on worked. Other issue could be the brake sensor switch; if it thinks the brake is being pressed it wont engage the cruise.
Old May 13, 2011 | 01:37 PM
BlackSS185's Avatar
yea check all you brake light bulbs
Old May 13, 2011 | 01:44 PM
N1ckateen's Avatar
if you press in on the clutch too many times without doing anything else it will trip an invisible code causing ur cruise not to work. it's happened to me 3 times. disconnect negative on the battery for a good 10 minutes and all will be well.
Old May 13, 2011 | 11:38 PM
chood711's Avatar
calm down...i said it happened to me once..not it happens to me all the time..
Old Aug 12, 2011 | 01:46 AM
Truckerz88's Avatar
Same happened to me too... My auto mechanic told me that I needed to replace it with a new cruise control lever to fix the problem...
Old Aug 12, 2011 | 02:20 PM
BYT*SS*TURBO's Avatar
Did you just flash the car again? Ive seen it cause the cruise to not activate on a couple occasions then it started working after a few mins or a couple of key cycles.
Old Aug 12, 2011 | 02:36 PM
It only happens when i sometime fill up with gas
Old Aug 12, 2011 | 02:39 PM
steddy2112's Avatar
Troo story
Old Aug 12, 2011 | 03:08 PM
That is strange and not at all related, which makes it even stranger lol
Old Jun 3, 2013 | 04:46 PM
jmfselu's Avatar
This just happened to me on my trip to memphis. I am a big Cruise control guy too, so i wasn't very happy. I will be checking all three of these things after work. I hope i get it figured out.
thanks guys!
Old Jun 3, 2013 | 05:21 PM
Check your bulbs in your 3rd brake light or if you have an LED 3rd brake light it can screw with it.
Old Jun 3, 2013 | 05:43 PM
turbosmart4's Avatar
Mine doesn't work either
Old Jun 3, 2013 | 06:26 PM
Gelladuga69's Avatar
The set of CC buttons on the steering wheel or actual signal lever?
Only found these on that site:
http://www.partstrain.com/store/deta...tml?vdesc=true
http://www.partstrain.com/store/deta.../ACD1987D.html
Old Jun 5, 2013 | 10:38 PM
rchiwawa's Avatar
My cruise control wouldn't work on a full tank of gas since the car was new and the dealer never found a solution. I'd have to burn off a gallon or so and regardless of it being on a road trip (no power cycling) or a half dozen starts, once a smidgeon of fuel was used, boila, it'd function. Damnedest thing, too. For driving between about 65k-75k miles it became intermittent regardless of fuel level. At 75k or so I replaced the front passenger wheel bearing assembly and the cruise control quirk for my TC went away. Now @ 90k
I have a hard time believing it still, months after the fact. Probably just my particular 'balt's gremlin
Old Jun 10, 2013 | 02:10 AM
bcc09ss/tc's Avatar
Could be one of your brake lights isn't connected all the way. That happened to me.
Old Jun 10, 2013 | 04:51 AM
ColeMart's Avatar
thanks guys!
Does it work at all? Or is it an intermittent issue?
My cruise doesn't engage once in awhile, and all I have to do is just tap the brakes, and it engages right after. No clue why it does this.
