cruise control not working
if you press in on the clutch too many times without doing anything else it will trip an invisible code causing ur cruise not to work. it's happened to me 3 times. disconnect negative on the battery for a good 10 minutes and all will be well.
Same happened to me too... My auto mechanic told me that I needed to replace it with a new cruise control lever to fix the problem...
This just happened to me on my trip to memphis. I am a big Cruise control guy too, so i wasn't very happy. I will be checking all three of these things after work. I hope i get it figured out.
thanks guys!
thanks guys!
Only found these on that site:
http://www.partstrain.com/store/deta...tml?vdesc=true
http://www.partstrain.com/store/deta.../ACD1987D.html
My cruise control wouldn't work on a full tank of gas since the car was new and the dealer never found a solution. I'd have to burn off a gallon or so and regardless of it being on a road trip (no power cycling) or a half dozen starts, once a smidgeon of fuel was used, boila, it'd function. Damnedest thing, too. For driving between about 65k-75k miles it became intermittent regardless of fuel level. At 75k or so I replaced the front passenger wheel bearing assembly and the cruise control quirk for my TC went away. Now @ 90k
I have a hard time believing it still, months after the fact. Probably just my particular 'balt's gremlin
My cruise doesn't engage once in awhile, and all I have to do is just tap the brakes, and it engages right after. No clue why it does this.
