p0833 check engine help
Old Jan 24, 2017 | 10:04 PM
LotusEater's Avatar
AWHILE AGO: my car started acting up, the cruise wouldn't work, and RPM's wouldn't drop when fully engaged clutch. I replaced the old Clutch Safety Switch. It went back to normal.
RECENTLY: My car will only work normal when I remove the battery harness, to allow the codes to clear from the ECM. The Codes eventually stack and stack p0833, until finally i get a check engine light. Its no way to drive a cobalt SS, very shifty.
WHAT TO DO:
I will Replace the bottom switch again tomorrow with a new one. 5 dollars from rockauto
I heard there is a second Switch ,the clutch position sensor, where do I buy this online?
Can i replace it myself, and then just remove the battery harnessed to clear any codes?
Please help.
Old Jan 24, 2017 | 10:51 PM
tomj77's Avatar
p0883 doesn't exist according to code list. are u sure that's what it was
Old Jan 25, 2017 | 09:28 AM
It exists tom, he probably has an lsj
https://www.cobaltss.net/forums/prob...itch-b-179146/
Old Jan 25, 2017 | 01:53 PM
LotusEater's Avatar
Thank you ECaulk. I will check out the link description. I do have a lsj Naturally aspirated blue cobalt ss.
Where do i find this position sensor switch. Is it listed here? 2007 CHEVROLET COBALT 2.4L L4 Clutch Pedal Position / Starter Safety Switch | RockAuto
Old Jan 25, 2017 | 02:09 PM
You have a LE5 not an LSJ.
The part number should be 22734989, thats pulling from another thread. Sounds like its near the steering column above the clutch pedal.
Old Jan 25, 2017 | 04:09 PM
LotusEater's Avatar
I already replaced this switch.
Is there a different switch up higher or something?
http://i281.photobucket.com/albums/k...tSSSC149-1.jpg
It couldn't be the same switch going bad in two weeks throwing the codes.
If I can get the codes to stop coming up I can drive normal again. Please help.
Old Jan 25, 2017 | 07:32 PM
LotusEater's Avatar
Just an update: I switched out the nuetral safety clutch switch with the old one and it does the same thing, so it works but my cruise still doesn't work. I have a feeling then that there is either A.) a problem with the connection to the ECM. B.) A fuse or something C.) I found out that loss of cruise control can sometimes be because of a blown out tail light or bulb. I will check all my brake lights tomorrow and hopefully I have some luck. Stay in touch.
