Two codes on 09 SS
Two codes on 09 SS
So today I went and got my car scanned and I have p0089 and p0140. 25psi tune along with catless downpipe and Zzp intake tube and high flow air filter. Now I know it's fuel pressure regulator that's messed up but idk how to go about this or what is wrong with it. Help would be appreciated!
If it bogs when you come to a stop, you might need to clean your TB. Mine did that and sometimes died and lights. cleaned the throttle body and it runs great now. Theres a tutorial on her and its easy to do, take maybe 45 min max if you dont really have experience.
No longer having a problem guys but thanks for the input! I just think some things didn't get set when my tuner had to redo my tune because not only did my battery die during the tune, my obdii fuse blew so he had to redo my tune just to make sure and he forgot to change those 2 fault codes. Everything runs fine lol.
I would give the car a few hundred miles before declaring the issue fixed. A lot of codes take a few drive cycles to pop back up.
OrangeCoba
09-25-2015 06:06 PM
