Hatrickstu's Detailing How-To
#108
What kind of results can I expect if I follow, but without a polisher? I have a few very light scratches I would like to take care of...I purchased a kit from Mequier that includes clay bars and a quick detailing spray and a couple compounds for scratches and swirls. Going to wax after all that and a few washes...not quite ready to purchase a polisher but I don't need mirror-like results just yet.
Also, where would you fit any touch up to the paint into this regiment? How well would touched up areas hold up to a polisher if I do get one?
#109
Haha. Beautiful cars man...your guide has been a big help.
#115
after you finish washing, for a final rinse take your nozzle off the hose and "flood" your car, meaning: use regular flow water pressure and start at the top and work your way down. The surface tension of the water will pull most of the beads off your car...that is if it's got a good wax job on it.
less beads of water = less water spots .....and the quick detail that you use to clay bar is easy to use between waxings to remove waterspots. just spray on an applicator, wipe a section down and wipe off. Should become part of the washing routine.
after you finish washing, for a final rinse take your nozzle off the hose and "flood" your car, meaning: use regular flow water pressure and start at the top and work your way down. The surface tension of the water will pull most of the beads off your car...that is if it's got a good wax job on it. less beads of water = less water spots
.....and the quick detail that you use to clay bar is great for between waxings to remove waterspots. just spray on an applicator, wipe a section down and wipe off. Should become part of the washing routine.
#116
tech to try and get rid of water spots is either clean water. or softened water. water softeners work decently for water spots.
im not too sure about brita water purifiers. that would take forever tho. just park ur car under shade and dry it off.
#117
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
#118
Apparently the Mr. Clean autodry system works pretty well. Purifies the water so you don't have the minerals in the water causing spots.
I've worked out a system of washing my car in sections rather than the entire thing and trying to dry really fast. It takes a while and you have to overlap if you spray too hard, but I get very good results with it.
#120
#124
You can get them at autogeek or any other large online car detailing place for about $10.
Its just another way to prevent swirls from being made and destroying our sanity.
