cams for 2.2
Old Aug 29, 2008 | 02:54 PM
SportRedLT's Avatar
cams for 2.2
i wanted to get new cams for my car and i found a nice set on CED and i was just wondering if i were to put those on what else would i need to do to the engine to make sure it works and doesnt blow up
Old Aug 29, 2008 | 03:09 PM
TurboTechRacing's Avatar
CED sells ground cams? I thought they were just blanks?
You might want to look at www.TurboTechRacing.com at the Comp Cams, they are the #1 seller for the ecotec and come in 5 different grinds to meet your building needs.
Old Aug 29, 2008 | 04:49 PM
Red07SSNA's Avatar
The GM Performance Cams listed are for race only engines and not meant for replacement cams.
From their site:
Note:
The GM Performance Parts ECOtec cam set (88958648 set or 88958636/7 individually) is an aggressive race cam. They are not stock-replacement cams; they require upgraded valve springs and retainers. These cams were designed for a race motor, using the ‘06 L61 as the starting point. The cams will not fit the 2.4L LE5 head and will not work with the stock ECM or lifters. They physically fit the 2.0L LSJ head, but the vacuum pump / cam sensor will not work in a stock engine.
Old Sep 2, 2008 | 03:42 PM
Grich171's Avatar
i have a set of stage 2 comp cams for sale right now
Old Sep 2, 2008 | 06:36 PM
IonNinja's Avatar
you need more time researching your purchase
Old Sep 2, 2008 | 06:39 PM
YellowLT's Avatar
I beg you please do more homework before you blow up your car. You can PM myself or halfcent any questions you may have and Myself or Halfcent should know the answer. What year is your car BTW?
Old Sep 2, 2008 | 11:56 PM
SportRedLT's Avatar
the car is an 08 and thats why im asking so many questions i really would rather not blow the car up. so i was looking and im thinking of going with the comp stage 1 cams in spring time now is there anything else i have to do to not blow the car up to make them work?
Old Sep 3, 2008 | 10:26 AM
007CobaltLS's Avatar
Can we clear something up because I guess I missed something in the last few weeks/months...if you have an 08, how can you get cams and I (07 LS) can't...I know in 07 they added the Cam Position Sensor, so did they change the 08 in some way that it will work, or does SportRedLT not know about that?
Old Sep 3, 2008 | 10:27 AM
originaladrian's Avatar
dont think u can with an 08 yet...or u would have to get blanks ground to what u want, the comp cams wont work.
Old Sep 3, 2008 | 01:13 PM
MP Cobalt's Avatar
You got to want for company's to make cams and all that for the 08 models, there brand new and probably have different setups than 05-07. I own a 06 and i'm getting cams installed this Christmas.
Old Sep 3, 2008 | 01:29 PM
2005-06 are the same
2007-08 are the same with the extra CPS
Old Sep 3, 2008 | 02:23 PM
SportRedLT's Avatar
alright thanks i really had no idea about the sensors my bad
Old Sep 6, 2008 | 01:34 AM
Maven's Avatar
There is currently no over the counter performance intake cam available for the 2nd Gen L61(07/08)
Exhaust will accept a Gen1 cam
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 26, 2015 06:44 PM
