Poor fuel mileage, What else can I do?
Bought an 06 SS 2.4/ auto a few months back. Had a four wheel alignment done, low rolling resistance tires @ 38psi, Mobil 1 synthetic oil, K&N air filter, and I get 28mpg hwy with the air off and windows up, trunk empty at 60-65 mph. I thought it would do better than that. I have a 91 Z07 Vette that gets 32.8mpg loaded down at 80mph when we travel! Any ideas?
Thanks
Thanks
Altitude kills. That's all I can say. I also have a 07 2.4, but with the manual tranny. I'm seeing similar mpg. However, this car is mostly driven in the city for short tips, and at slow speeds, mostly 30-40 mph. My car was rated for 29/34. This is exactly why the EPA changed the tests for mpg. IIRC, the current tests reduced the numbers quite a bit and you are seeing mileage that reflects the more accurate results. Also, the tranny plays a factor. You have a 4-speed that weighs more than the 5-speed I have. More weight and fewer gears are bad for fuel economy. Also, I believe the old tests were set to test hwy economy at 55mph. Therefore, at a higher speed, and higher rpm's, you would reduce your fuel economy.
Also, what octane are you filling it with? GM recommends premium (91 or 93 depending on where you live, and your altitude). Lower octanes are okay though.
when I use 89 I get about 29-30 highway at about 65 on less than 1/2 hour drives. but if its a long ass trip using 93 I avg about 41. 06 2.4 also
I have a lot more miles than you but... mines completely stock.
i have 2.4 sedan with automatic tranny i will post my gas mileage tomorrow because i have to drive from north jersey to Baltimore then on saterday i have to drive back so i will get back on the gas mileage .....last time i think i got 33mpg on that same trip but that time i was really good and feathered it the whole way and used cruise control .......usually i get about 27-29 mpg when going 70-85mph no cruise control and not maintaining steady rpms
I have a 2.2/auto but at 65 on the highway I get 34 mpg. With 20k have you changed the fuel filter. I dont know what the recommendation is on mileage replacement but all it one bad tank of fuel and your fuel filter can partly or even fully clog. I had it happen to me once. I installed a new filter before i went on a 1500 mile road trip. Half way on the trip, I filled up for the 3rd tank of the trip and by the end of that tank of gas the car ran like ****. Stopped in to the closest dealer and after some tests they told me my fuel filter was clogged. They replaced it and the car ran fine.
I have an '08 G5 GT with the auto. (2.4L LE5) And I use 87 octane. Is that why? If so can I get some good links to why? (My wife doesn't believe it)
I tend to get 23-24 city. And got under 30mpg from Charleston up to Washington DC. I want to know what I am doing wrong. The car has 6K miles on it. Cruise was set 70-80mph the whole way.
I have a 2.2L auto and get 37 mpg doing 70mph & a whopping 45 mpg doing 55mph. Then again I got an intake, full exhaust, full syn oil & ngk IX plugs. City driving i get abuot 26-27 mpg.
GM recommends 91 rated octane(I think) for the 2.4. I used to use 89 or 91(depending on gas station) and I received lower fuel mileade, but then again gm recommends 87 w/2.2L
Sl0wbaltSS
Nov 21, 2018 11:11 PM
