cry02?
Old Jan 8, 2009 | 09:37 PM
StreetglowCobalt's Avatar
cry02?
Heard good stuff about it, safer, easier install, 25-35 hp. anyone have this or know anything about it?
http://www.designengineering.com/pro...sp?m=sp&pid=72
Old Jan 8, 2009 | 09:40 PM
XM15's Avatar
This is a cooling mod though, and a stockish 2.2 doesn't need that like an ss/sc does.
I'm not convinced that the cooling will negate the bad effects of having something blocking part of the intake system.
The cry02 intercooler spray bar is a good idea for f/i applications though.
Old Jan 9, 2009 | 01:42 AM
Sentry's Avatar
I'm planning on getting a bottle of this soon. Basically it just cools your intake/intercooler to the extreme.
On the tests I've seen done, on a ~300hp srt4 it made 15hp. Not bad if you're making that kind of power.
Old Jan 9, 2009 | 12:30 PM
Does this install on a 2.2 non turbo
Old Jan 9, 2009 | 12:32 PM
brickerenator's Avatar
um
yes
doh
and you won't see 25hp
maybe 1
or 2
Old Jan 9, 2009 | 12:35 PM
Psykostevo's Avatar
Cryo is really just intended as an Intercooler sprayer. Unlike Nitrous, CO2 doesn't contain combustible oxygen so it won't add the same power even if it is cold.
Old Jan 30, 2009 | 05:35 PM
ioncougar's Avatar
From what I understand about these systems is that they are pretty modular. They say that the normal set up would be for the C)2 to go to the intake cooler, then to the fuel line cooler, and then to use an intercooler sprayer as the vent. You don't need to use the sprayer you can just vebt it after the fuel line or intake cooler or use a purge system as the vent. C02 is not injected into the intake or any part of the engine but rather a heat sink sort of block that freezes and extracts heat. In my opinion a cooler intake charge as well as cooler fuel could help, but I'm still not sure if it would be worth the money on a N/A setup such as mine. It is cheaper an way safer than nitrous injection but probably no where near as effective.
CbYellowSS
Aug 22, 2007 12:27 AM
andys5k
Jul 14, 2007 07:47 PM
WhiteSSBalt
Nitrous Oxide
Jun 4, 2007 06:18 PM
