question on these motors.
Old Feb 15, 2009 | 05:03 PM
pykie's Avatar
I have a 2007 2.2 and i have been looking around for other 2.2 motors, i came acrossed a smashed 2008-2009 2.2 with a good motor (car was rearended) motor only has 15,000 on it.
now if i was to take that motor and build it for my turbo and put it into my car will it be ok with my 07 computer?
i do not have the SAI in my car either.
Old Feb 15, 2009 | 05:23 PM
Phoenix454's Avatar
Why don't you take the comp from the wrecked car as well and tune the new comp from the wrecked car for the turbo also the newer motors are different cause of the vvt so you would prolly need the new comp reguardless. I'm kinda new to the fuel injected 4 banger sceen so some one correct me if I am wroung. But I am pretty sure you gonna need to take the comp from the wrecked car with you also youll need to tune the comp reguardless if you turbo it just to get it to run right.
Old Feb 15, 2009 | 08:50 PM
HunterKiller89's Avatar
i cant say for sure...but with every other motor swap in a cobalt (be it pre-'07, 07-08, LAP, Le5, LSJ, LNF, etc.) involves not only swapping PCMs but swapping every electronic device on the car, such as ABS sensors, gauges, airbag sensors, etc. Its definitely not worth it. Find a motor of the same year
Old Feb 15, 2009 | 08:52 PM
sport08's Avatar
i think you are correct but im not 100% sure either
Old Feb 15, 2009 | 08:58 PM
ssyellowss's Avatar
i highly doubt it. the new 2.2 (LAP) has VVT. plus as stated just about every other electronic device would need to be swapped
Old Feb 16, 2009 | 08:43 AM
pykie's Avatar
Okay thanks, i wanted the VVT but i gutt it be to much work, plus the place also has some 2007 L61 motors too.
thanks for the info.
Old Feb 20, 2009 | 01:32 PM
Maven's Avatar
a 2008 2.2 would work too...
Old Feb 21, 2009 | 03:57 AM
jestinG5's Avatar
Yup, 09 will be a bitch to do
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
