Need to know if my boost levels are safe
Old Feb 16, 2009 | 10:20 PM
Redefined1's Avatar
I`m planning on doing a 2.5 pulley with the zzp heat exchanger and the AIS stage 1 trunk mount meth kit. Will my boost levels be safe? I just need to know what is going to break on my engine with about 20-21 psi.
Old Feb 16, 2009 | 10:24 PM
Cobalt4theWin's Avatar
Not sure about the SS/SC, but I'm pushing 22 PSI on my TC and it's fine. Sorry I don't have a better answer for you, I'm sure someone will. gl
Old Feb 16, 2009 | 10:31 PM
supermantxz24's Avatar
get the dual pass also and you should be fine with meth and the zzp heatexhanger just keep an eye on your temps and make sure whoever is tuning your car knows their ****
Old Feb 16, 2009 | 10:34 PM
Razor564's Avatar
The MOSSSSSSSSSSST important thing right there.
Old Feb 16, 2009 | 10:35 PM
Redefined1's Avatar
my tuner knows what he`s doing. im not asking if my cooling mods will be enough im asking if the pressure from the boost will blow heads or gaskets or anything
Old Feb 16, 2009 | 10:45 PM
HunterKiller89's Avatar
correct
avoid knock at ALL costs (run an unusually safe tune...nothing too ridiculous, but dont run it on the edge) and you'll be fine
Old Feb 16, 2009 | 11:13 PM
Razor564's Avatar
Oh...well no. But its not boost that blows these cars up its heat from that heaton.
Old Feb 16, 2009 | 11:21 PM
Area47's Avatar
Rent me! per hour
who's the tuner?
BUY AN EGT GAUGE.
Old Feb 16, 2009 | 11:32 PM
Redefined1's Avatar
the tuner is a local friend that runs a shop called "all out performance" his name is wes
Old Feb 16, 2009 | 11:37 PM
Area47's Avatar
Rent me! per hour
cool, just remember. just because the afr is fine, doesn't mean the cylinder temps are ok. hence me saying buy an egt
Old Feb 16, 2009 | 11:39 PM
Redefined1's Avatar
i already feel stupid for asking, what is an EGT?
Old Feb 17, 2009 | 12:29 AM
exhaust gas temperature sensor
Old Feb 17, 2009 | 12:32 AM
Area47's Avatar
Rent me! per hour
measures the temperature of the exhaust coming out of the port. mine is 1.5 inches away from the exhaust port on number 4. i had this gauge before i had a wideband. im oldschool when it comes to things
Old Feb 17, 2009 | 04:29 AM
Maxim_X's Avatar
That is going to be a hot setup so take the advice. Make sure you never run out of meth, it's going to keep you cool more than any of that other stuff.
As far as whats going to blow, with that boost you should be fine but if you get a bad tune say by to the piston ringlans. I would shoot for just over 11:1. Don't creep up near 12's
Old Feb 17, 2009 | 04:34 AM
car_guy_09's Avatar
Just be sure the tune is PERFECT and watch your temps (IAT2 and EGT) And you should be fine
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Rduncanss06
Sep 27, 2015 11:17 PM
