Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
how to install OTTP H/E
Old Mar 21, 2009 | 12:23 PM
bernandovelasquez's Avatar
ok just to clear up a few things, hopefully lsjwannab can give us an idea...
do the H/E bolt up to the crash bar? if so holes have to be drilled right?
and which nipple is in and which is out?
I know the inlet and outlet is supposed to be on the right and the drain should be on the bottom left, so looking at it from this angle is the top nipple the inlet and the bottom the outlet?
also would it be better to remove the stock H/E and just have the ottp h/e or is it better to combine the old one with the new one ? I saw two diff diagrams, one with both the h/e working together and one with just the ottp H/E... what is the best way to to use?
Also what are the four smaller brackets on the H/E is for? because my H/E only came with two bolts and those bolts look like they are for the larger brackets welded to the top of the H/E.
Last edited by bernandovelasquez; Mar 21, 2009 at 12:35 PM. Reason: Automerged Doublepost
Old Mar 21, 2009 | 12:27 PM
EXsoccer1921's Avatar
yes, crash bar.
yes, two bolts for the larger welded on brackets.
yes, you have it oriented correctly
yes, top is inlet
yes, bottom is outlet
Old Mar 21, 2009 | 12:30 PM
lsjwannabe's Avatar
Everything ex said
I would suggest removing the stock unit personally.
The 4 tabs come on the core unit so don't worry about those.
Old Mar 21, 2009 | 12:34 PM
so we have to drill holes on the crash bar... are those two brackets enough support to hold that thing at high speeds and possibly hitting pot holes and what not?
Old Mar 21, 2009 | 12:38 PM
i'm going to keep the stock unit on. but i'll have the coolant run through it first
Old Mar 21, 2009 | 12:39 PM
hey thanks for such a fast reply!! talk about customer service, by far the best vendor for cobalts!!
lsjwannabe's Avatar
Yes they do the job quite well
Old Mar 21, 2009 | 02:25 PM
fzn14's Avatar
When i installed mine i removed the stocker so i could space everything out...better cooling IMO
Old Mar 21, 2009 | 02:28 PM
Black SS/SC 06's Avatar
That's what I plan on doing as well.
Old Mar 21, 2009 | 07:04 PM
ok I managed to get it up!! here are some pics.
thats a friend of mine helping me hold **** in place....
Last edited by bernandovelasquez; Mar 21, 2009 at 07:04 PM. Reason: Automerged Doublepost
Old Mar 21, 2009 | 07:07 PM
blue05ss/sc's Avatar
nice nice im about to buy mine really soon def put pics up of the final product with bumper on
Old Mar 21, 2009 | 07:14 PM
Thanks for the pics man, helps me with my project as well lol.
Old Mar 21, 2009 | 07:20 PM
yeah it got too dark to get pics in the end, but everything fit smooth, I had to drill two holes for the brackets, (on crash bar) but in the end the bumper went back on without a prob and fitted perfect! i will take pics tomorrow with the bumper on, (got some more pics to post as well)
Old Mar 21, 2009 | 11:43 PM
Sweet
We should start making stickies in the vendor threads too
This has some good info in it
Last edited by Black SS/SC 06; Mar 21, 2009 at 11:45 PM. Reason: Automerged Doublepost
Old Mar 21, 2009 | 11:58 PM
MarqueDo7BabyBalt's Avatar
nice man, wasnt that hard right...mostly just drill 2 holes and ur done lol
Old Apr 1, 2009 | 09:57 PM
cli3e0339384398jk's Avatar
how are your temps since install?
Old Apr 4, 2009 | 10:21 AM
what I notice the most is that the temperatures drop a lot faster when the fan kicks in, temperatures have also gotten better, it's worth it... trust me..
Old Apr 6, 2009 | 02:44 AM
I am never taking that damn front bumper off again!
Old Apr 6, 2009 | 03:00 AM
SSKobald's Avatar
The picture with the bumper on, is that the drain plug im seeing hang under the lip on the passanger side?.
Old Apr 6, 2009 | 04:02 PM
Yea thats because my lip is f'd up
I am getting a new one soon so you wont see it lol.
Someone hit the front lip and the centerpiece is no longer there.
Old Apr 7, 2009 | 12:33 AM
SS/SCking's Avatar
do you still have the stock h/e black?
Old Apr 7, 2009 | 12:43 AM
Yea in the garage
Old Apr 7, 2009 | 12:48 AM
SS/SCking's Avatar
i wanted to know if you were evenn running it lol.Looks like il just have the stock radiator left....no ac or he soon.
Old Apr 7, 2009 | 12:52 AM
No I took that **** out lol
Old Apr 7, 2009 | 01:09 AM
SS/SCking's Avatar
cool me too than soon
