how to install OTTP H/E
ok just to clear up a few things, hopefully lsjwannab can give us an idea...
do the H/E bolt up to the crash bar? if so holes have to be drilled right?
and which nipple is in and which is out?
I know the inlet and outlet is supposed to be on the right and the drain should be on the bottom left, so looking at it from this angle is the top nipple the inlet and the bottom the outlet?
also would it be better to remove the stock H/E and just have the ottp h/e or is it better to combine the old one with the new one ? I saw two diff diagrams, one with both the h/e working together and one with just the ottp H/E... what is the best way to to use?
Also what are the four smaller brackets on the H/E is for? because my H/E only came with two bolts and those bolts look like they are for the larger brackets welded to the top of the H/E.
Last edited by bernandovelasquez; Mar 21, 2009 at 12:35 PM. Reason: Automerged Doublepost
ok I managed to get it up!! here are some pics.
thats a friend of mine helping me hold **** in place....
Last edited by bernandovelasquez; Mar 21, 2009 at 07:04 PM. Reason: Automerged Doublepost
yeah it got too dark to get pics in the end, but everything fit smooth, I had to drill two holes for the brackets, (on crash bar) but in the end the bumper went back on without a prob and fitted perfect! i will take pics tomorrow with the bumper on, (got some more pics to post as well)
We should start making stickies in the vendor threads too
This has some good info in it
Last edited by Black SS/SC 06; Mar 21, 2009 at 11:45 PM. Reason: Automerged Doublepost
