Need Wideband Help
Old Mar 25, 2009 | 08:15 PM
BlkWdoSS's Avatar
Need Wideband Help
I am wanting to install an AEM UEGO Controller on my 2006 SS/SC. The instructions with the wideband states that it needs to be 18" downstream from the head. I measured this and it appears that it would put the wideband where the catalytic converter is.
So my question is how do I go about placing my wideband? Can I place it upstream from the cat? Can it be downstream from the cat? Or do I need to eliminate the cat?
any help is greatly appreciated,
thanx,
PD
Old Mar 25, 2009 | 08:57 PM
Kennyspec's Avatar
place it just in front of the cat.
Old Mar 25, 2009 | 09:34 PM
06SS/SC STAGE2's Avatar
^^^^ what he said^^^^^
Old Mar 25, 2009 | 10:06 PM
Jrhdpaintball's Avatar
also try and put it as close to 12 oclock positin as possible.. anything but pointing down...
Old Mar 25, 2009 | 10:14 PM
BlkWdoSS's Avatar
ok thank you all for your help, its greatly appreciated
thanx,
PD
Old Mar 25, 2009 | 11:09 PM
massivematt's Avatar
you dont have to get that technical for real.. Just put it an inch away from the original O2 sensor. at a 15 degree angle.
Old Mar 25, 2009 | 11:14 PM
Greased's Avatar
15 degree angle in refrence to what, the ground? or the headers?
Old Mar 26, 2009 | 08:04 AM
Thumbs up diagram
http://www.aempower.com/images/produ...%2030-4100.pdf
check out page 8. It can be 10 to 15 degrees from either the 12 oclock position or 6 oclock position. Mine is from the 6 oclock because thats where the bung was welded when i got the downpipe.
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
xxenjoi11
Sep 29, 2015 12:36 PM
n20saturn
Sep 21, 2015 01:50 AM
