Need Wideband Help
Need Wideband Help
I am wanting to install an AEM UEGO Controller on my 2006 SS/SC. The instructions with the wideband states that it needs to be 18" downstream from the head. I measured this and it appears that it would put the wideband where the catalytic converter is.
So my question is how do I go about placing my wideband? Can I place it upstream from the cat? Can it be downstream from the cat? Or do I need to eliminate the cat?
any help is greatly appreciated,
thanx,
PD
thanx,
PD
http://www.aempower.com/images/produ...%2030-4100.pdf
check out page 8. It can be 10 to 15 degrees from either the 12 oclock position or 6 oclock position. Mine is from the 6 oclock because thats where the bung was welded when i got the downpipe.
n20saturn
Sep 30, 2015 12:26 AM
