Flywheel Help
Old Mar 27, 2009 | 09:49 AM
chrism0589's Avatar
Flywheel Help
i recently purchased an exedy stage 1 clutch. i haven't installed it yet but i wanted to know if i should get a new flywheel too. i just want to know how much better it would be to have one and if its worth it. also which one would be the best to get.
any help???
Last edited by chrism0589; Mar 27, 2009 at 09:49 AM. Reason: Automerged Doublepost
Old Mar 27, 2009 | 09:51 AM
TurboTechRacing's Avatar
You need to either re surface the stock flywheel (a machine shop will need to do this)
OR
Get a SPEC aluminum flywheel. With the flywheel you will notice much faster revs and better throttle respoce...
Old Mar 27, 2009 | 11:31 AM
chrism0589's Avatar
i cant see the responces until i post something. wtf
OR
why the spec one??
Wtf!!
Last edited by chrism0589; Mar 27, 2009 at 11:31 AM. Reason: Automerged Doublepost
Old Mar 27, 2009 | 11:35 AM
SPEC has a great flywheel. Fidanza is cheaper, but some have had issues with them breaking, we carry both... SPEC is better (more reliable)
Old Mar 27, 2009 | 11:52 AM
XM15's Avatar
I've got a Fidanza and I immediately noticed the difference in the revs. You might as well get a new flywheel while you have everything opened up.
Old Mar 27, 2009 | 01:33 PM
chrism0589's Avatar
Old Mar 27, 2009 | 01:35 PM
Originally Posted by chrism0589
What is this post about?
Old Mar 27, 2009 | 03:32 PM
Jn2's Avatar
Jn2
you can get w/e flywheel you want, but if you getting a badass clutch, why use a crappy stocker one it, get a fidanza or spec flywheel, the flywheel will be coming off anyway, so your not paying them to do any extra work, yes spec cost more, but thats for a reason, its better, the fidanza is cheaper, but they have been known to crap out after a while, check the cavis, they run the same thing, aaron is just trying to save you a headache they carry both flywheels and im sure they would match any competitors price(considering its not a wholesale price), so pick one and go for it, like i said, the tranny is down, the flywheel is out...i dont see a reason not to
Old Mar 27, 2009 | 03:35 PM
Good points. Thanks.
Old Mar 27, 2009 | 04:31 PM
PsychoCam's Avatar
Fidanza flywheel will not work with a exedy clutch, you need the exedy light weight flywheel. Like I will be installing on suday morning
Old Mar 27, 2009 | 05:14 PM
bluebaltjim's Avatar
just installed the exedy stg1 clutch and exedy lightweight flywheel about 3 weeks ago, very good combo. the clutch is very heavy at first(about 500-600 miles)but then it's almost like the stocker in feel. the flywheel is about 9-10 lbs lighter and there is a huge difference in first and second gear, as you go up from there it's alot less noticeable.
Old Mar 27, 2009 | 05:36 PM
Jn2's Avatar
Jn2
now will the stg1 work for a ls/sc car? i dont see trq specs like for that of spec's clutchs, or else i would go all excedy...
Old Mar 27, 2009 | 05:37 PM
Yeah we have the Exedy stage 1 on TTR for the 2.2L ecotec....
Old Mar 27, 2009 | 05:42 PM
Jn2's Avatar
Jn2
i know u have it just dont know if it will hold the power of a ls/sc car, ~250trq
Old Mar 27, 2009 | 05:43 PM
Honestly I wouldnt try it.... You put in $300 into the clutch PLUS all time time/labor to install it and then find out you have to upgrade a year (or less) later? Do it right the first time, and save...
Old Mar 27, 2009 | 05:46 PM
Jn2's Avatar
Jn2
yeah thatsd what im saying im planning no the stg2+ but didnt know if the excedy one could hold as much, since they only have a stg1 and nothing else
Old Mar 27, 2009 | 05:47 PM
Exedy does lack on the high performance clutch kits for the 2.2L...
jas09ss
Sep 26, 2015 01:06 PM
n20saturn
Sep 21, 2015 01:50 AM
ashalle2
Sep 16, 2015 10:36 PM
brett.higgins3
Sep 14, 2015 01:48 PM
