Factory Airbox Mod
Old Mar 30, 2009 | 11:36 PM
Matt M's Avatar
Factory Airbox Mod
We have been doing dozens of dyno pulls on our new SS/T trying out new parts and tuning in multiple combinations. After trying a few intake mods, I decided to modify the factory airbox. Here is a step by step inexpensive modification if anyone is interested:
The airbox inlet and fenderwell tube are shown here. The ID of the fenderwell tube necks down to about 2.5", and therefore becomes restrictive on high HP setups.
After removing the airbox, notch the plastic as shown:
Next, cut the fenderwell tube just before it starts to bend. Remove the plastic brackets from the tube. I cut all of the bracket off and it left a hole in the tube. You can leave some of the bracket on and avoid the hole. It will still fit fine in the new configuration.
With the airbox back in place, connect the fenderwell tube to the airbox using a 3.25" silicone coupler and 2 clamps.
Completed:
Method #2 without silicone coupler to connect snorkel:
Remove the headlight and then remove the headlight mounting bracket shown here-
Unplug the MAF sensor and remove the airbox lid:
Unbolt and remove the airbox:
Remove the snorkel bracket bolt shown to the right:
With the tire removed, you can more easily access the retainer clip behind the snorkel:
Cut off the long snorkel bracket as shown:
Cut the snorkel just before the first bend and smooth the edges:
Pic showing how the snorkel will slide into the lower airbox tube once the box is reinstalled:
With the airbox reinstalled, slide the snorkel up through the fenderwell. Use a screw to hold the pieces together:
K&N air filter installed:
Installing the AEM silicone intake:
Position the clamp on the turbo inlet for easy tightening as shown:
Connect the coupler to the airbox lid before fastening the lid to the airbox. This makes it easier to keep the coupler straight on the MAF housing:
Connect the airbox lid and fasten the clamps. Plug in the MAF sensor. Install the vent tube into the silicone coupler with the opening facing towards the MAF. Connect the vent tube assembly:
Old Mar 31, 2009 | 12:01 AM
bri2203's Avatar
Hey Matt,
Thats nice of you to post something like that as a vendor.
Looks like you extended the snorkle a few inches futher?? What differences has it made?
Old Mar 31, 2009 | 12:16 AM
Matt M's Avatar
Originally Posted by bri2203
Hey Matt,
It is actually shortened a few inches. It normally curves forward and sits just behind the bumper skin.
We did a few mods to the stock intake and picked up over 10HP. I don't have numbers for this mod alone, but I'd guess it's worth a few HP.
Old Mar 31, 2009 | 01:07 AM
Zander916's Avatar
Damn... all I'm getting is
Anyway to repost the pics for me?
Anyone else having the same problem?
Old Mar 31, 2009 | 01:10 AM
hiltu's Avatar
X2 for no pics
Old Mar 31, 2009 | 01:34 AM
mr_buddha's Avatar
pics no work
Old Mar 31, 2009 | 01:37 AM
celicacavy's Avatar
X3 for no pics
Old Mar 31, 2009 | 01:40 AM
koch1ar's Avatar
they did work. I saw them before the first post. matt you must have moved the pics. From the pics it looked like in inlet flange of the air silencer attatched to the airbox
Old Mar 31, 2009 | 10:40 AM
Matt M's Avatar
Yeah, they were working, but they migrated my website and they keep screwing everything up. I'll get them fixed this afternoon. Sorry.
Old Mar 31, 2009 | 10:43 AM
widowedeight's Avatar
pm when fixed? also times 2 on what the dyno dif was
Old Mar 31, 2009 | 12:39 PM
Cobalt SS 2009 TC's Avatar
the pics don't work
Old Mar 31, 2009 | 01:16 PM
Zander916's Avatar
Sounds good! I appreciate it!
Old Mar 31, 2009 | 01:18 PM
jwhitten's Avatar
subd for working pics, sound intresting
Old Mar 31, 2009 | 05:07 PM
1WhiteSSTC's Avatar
i can see pics just fine, the rest of u must be at work and has pics blocked by your IT guy
Old Mar 31, 2009 | 05:09 PM
crypticscifer's Avatar
Damm Proxies
Old Mar 31, 2009 | 05:10 PM
orbalt08's Avatar
Pics are working now!
Old Mar 31, 2009 | 05:18 PM
1WhiteSSTC's Avatar
Originally Posted by crypticscifer
Damm Proxies
the joys of not being chained to a desk
Old Apr 4, 2009 | 01:20 PM
Zander916's Avatar
THANK YOU MATT!!!
I just did the factory airbox mod. It was pretty easy and straightforward. It didn't take very long to do and only cost me a few dollars.
I'm tuned with K&N drop in and BPV spring upgrade. I'm not going to lie and say it was like night and day or something like that. But a difference was noticed.
I used to have a dead spot right around 6K rpm to 7K rpm where the rpm rise was noticeably slower. After the mod that dead spot is pretty much gone.
HUGE thanks to Matt who posted it!
It's weird that GM did that. It starts out 3"... necks down and then returns to 3"...
Old Apr 4, 2009 | 05:44 PM
08inBama's Avatar
why wouldn't you just remove the snorkel all together?
Old Apr 4, 2009 | 07:08 PM
Zander916's Avatar
You could, and I gave that thought. But it would just be like a short ram pulling in air from the engine bay. It wasn't difficult at all to just do this and get cold air. It's really not hard at all. Didn't take very long either.
Old Apr 4, 2009 | 08:11 PM
1WhiteSSTC's Avatar
kinda like the charge piping
bump for the OP, pics not showing anymore......
Old Apr 4, 2009 | 08:41 PM
Matt M's Avatar
Aside from drawing air from inside the fenderwell, the snorkel is also nice because it has a radiused inlet just like a velocity stack. This can improve airflow over a tube that just begins without a radius.
THANK YOU MATT!!!
I'm glad you like this mod. It really is easy and we are still using it on our upgraded turbo. We also have the KN drop in.
Old Apr 4, 2009 | 09:40 PM
madlion's Avatar
can someone post a how to w/ pics please please
Old Apr 6, 2009 | 01:25 PM
xray_racer's Avatar
Thumbs up
^^x2
Old Apr 17, 2009 | 11:30 PM
Matt M's Avatar
Pics are fixed. Sorry it took so long. My website company took a while to get the image issues straightened out.
