Turbo
Old Apr 3, 2006 | 04:13 PM
Vetteman99's Avatar
Turbo
What Turbo do you think i should put on my Black '06 Cobalt ss coupe also if not a turbo intercooler combo what intercooler should i get with it.
Old Apr 3, 2006 | 04:17 PM
3fo893013L's Avatar
SEARCH!
Nothing out yet and too much development still needs to be done until otherwise.
Old Apr 4, 2006 | 10:20 AM
celicacobalt's Avatar
are you custom building a kit for yourself? if so i say go witha gt28rs ball bearing turbo and a sparco intercooler that measures the right size to fit then have a shop do all the piping for you, if you want a kit then youll have to wait for hahn racecraft which should be out this month or next i think
Old Apr 4, 2006 | 01:57 PM
g5mike's Avatar
i have to agree with celicacobalt this one will spool up quickly, and if you have the 2.2 you can expect hp gains in the mid 200hp range
Old Apr 4, 2006 | 08:16 PM
Vetteman99's Avatar
Intake
If you don't have a turbo or super charger would a intake do any thing
Old Apr 4, 2006 | 08:20 PM
mike25's Avatar
yea the cai just pulls more cold air into it to cool it down so you could see about 10 hp gain
Old May 8, 2006 | 01:25 AM
97CIVIC's Avatar
Wait For The Hahn Turbo Coming Soon!
Old May 8, 2006 | 03:25 AM
NJHK's Avatar
Ball bearing turbos aren't for everyone...
Also ball bearing turbos include more maintenance. If you have to replace the whole cartridge, you might as well buy a new turbo for the price it's going to cost you. Sure, they spool slightly faster but it's nothing that you are guaranteed to need.
And you mean Spearco intercoolers...not Sparco. Any decently made intercooler will work fine...you can find them on ebay for a dime a dozen.
EDIT: If you have a problem with a ball bearing turbo, good luck finding a place that will fix the issue cause alot of shops don't deal with them.
Old May 8, 2006 | 03:28 AM
NJHK's Avatar
You really shouldn't give people guestimations of power increases.
Best answer you can give someone is to put it on and dyno it.
Old May 8, 2006 | 03:32 AM
NJHK's Avatar
The turbocharger itself isn't what determines your power gains...so you in reality can't EXPECT mid 200 HP by just putting a turbo on.
The amount of PSI you're running, the size of the turbo and your a/f mixture are the biggest factors of how much power you'll gain.
Also, spool timing...if you're worried about spool timing, match a turbo to your motor properly. If you don't know how to, get a compressor map and learn how to read one.
Want to learn how to read compressor maps?
Old May 8, 2006 | 03:37 AM
NJHK's Avatar
The turbo itself really depends on what you're looking for as far as spool timing, RPM range and efficiency.
As far as the intercooler, any decently made intercooler will work fine.
Are you planning on building your own kit? If so, read this before you buy anything:
How To: Build your own ECOTEC Turbo Kit
Old May 8, 2006 | 08:54 PM
savior's Avatar
once again, we have been raped by NJHK
Old May 8, 2006 | 09:08 PM
Vetteman99's Avatar
For the hahn turbo what web site is that on
Old May 8, 2006 | 09:10 PM
Brian MP5T's Avatar
No FMIC... Limits you to 4 Psi with a turbine
Old May 8, 2006 | 10:55 PM
97CIVIC's Avatar
I GOT IT OF MY JULY ISSU OF TURBO MAG,, IT MAKES 222.6 HP AND 248.9 TQ, STILL NO PRICE
Old May 8, 2006 | 11:40 PM
NJHK's Avatar
LOL
Once again, you made me giggle...
Old May 8, 2006 | 11:41 PM
NJHK's Avatar
http://www.hahnracecraft.com
Old May 8, 2006 | 11:55 PM
zomghax's Avatar
Awesome thread Adam.
Old May 9, 2006 | 12:01 AM
NJHK's Avatar
Thank you.
FYI: I'll be updating it every so often.
Old May 9, 2006 | 03:50 AM
Brian MP5T's Avatar
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
