Rear Caliper Piston help ASAP!!!
Old Apr 16, 2009 | 07:47 PM
kissmySS08's Avatar
hey do any of you guys know how to compress the rear caliper piston on the TC??? i tried with a c clamp... and tried turning it clockwise with the two holes on the piston and it isn't working and i need to get back on the road tonight. help is GREATLY APPRECIATED!!!
any ideas??
Last edited by kissmySS08; Apr 16, 2009 at 07:47 PM. Reason: Automerged Doublepost
Old Apr 16, 2009 | 07:48 PM
ilovecars's Avatar
push harder lol.
Old Apr 16, 2009 | 07:50 PM
kissmySS08's Avatar
i've tried as hard as i could and it won't budge, but turning it doesnt seem to work either
Old Apr 16, 2009 | 07:56 PM
joeyjetta46's Avatar
is ur e brake up?
Old Apr 16, 2009 | 08:01 PM
ilovecars's Avatar
Originally Posted by joeyjetta46
is ur e brake up?
ROFL! omg that would be so funny
wait isent it off the car?
Old Apr 16, 2009 | 08:09 PM
harryresh's Avatar
i had this same problem. you have to take a needle nose pliers and use the grooves on the piston to twist the piston clockwise as you push it in. you basically have to screw it in. i was told this is used so it will come out so you dont have to pull your e-brake out further as your pads wear down
Old Apr 16, 2009 | 08:13 PM
exiged's Avatar
you need to get a spanner wrench. they rotate back in.
Old Apr 16, 2009 | 08:15 PM
harryresh's Avatar
a needle nose is free and harmless if you place a rag around the tips of it
Old Apr 16, 2009 | 08:17 PM
SlyderRE's Avatar
autozone or sears sells a tool for this....... its like $4
madmark's Avatar
bingo!!!!!! go to autozone and get a universal caliper compressor(a cube with alot of circles)and spin it clockways till it stops and then back it up half a turn
Old Apr 16, 2009 | 08:37 PM
kissmySS08's Avatar
i give up....yeah the ebrake was off and i tried the needle nose... it turned and i was pushing in on it, but it wasnt moving... might just take it to the dealer tomorrow cause they said it'd only be $50 to install them?! thanks though guys
Old Apr 16, 2009 | 11:59 PM
harryresh's Avatar
use some muscle boy! or go get ur mom to do it for yah...lol
Old Apr 17, 2009 | 02:27 AM
kissmySS08's Avatar
i had my friend come over who owns one and he did his rear pads before... he said you have to twist it like on the SS/SC but we couldn't get it to move, so ill let the dealership mess with it/break it so i dont have to pay to replace it
Old Apr 17, 2009 | 05:55 AM
metroplex's Avatar
Loosen the bleeder screw so the fluid has a easier time leaving the caliper. I am not sure why everyone pushes the old fluid back through the ABS pump.
Old Apr 17, 2009 | 11:33 AM
mjrchabot's Avatar
Putting pistons back in suck... I had removed mine from the Brembos to do some work, and they were NOT fun putting back in.
Old Apr 17, 2009 | 11:36 AM
metroplex's Avatar
What's the big deal? Just loosen the bleeder screw, hook up a hose, and push the piston back in. Just make sure to bleed the hydraulic system afterwards. When you push the piston back in, where do you think the fluid is going? To limbo? It's going back through the system and into the ABS pump / master cylinder. Rather than make extra work for yourself, loosen the bleeder screw so the fluid gets pushed outside making your job easier.
Did you know that you're supposed to be able to push the pistons back in by hand (for the normal front calipers). They're not supposed to bind up at all.
Old Apr 17, 2009 | 12:10 PM
glhs379's Avatar
if you use plyers, make sure not to slip and rip the piston
Old Apr 17, 2009 | 03:40 PM
SSpdDmon's Avatar
If you guys are having problems like this, maybe yall should just stick to oil changes and leave the rest up to qualified mechanics.
Old Apr 17, 2009 | 03:50 PM
Terminator2's Avatar
Bingo. Once you do that you can compress the caliper with ease. Just bleed the brakes afterwards.
Old Apr 20, 2009 | 01:15 AM
REIGN SS's Avatar
Original Hayden Fanatic
*Moved to Suspension, please post in the correct section*
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
