Rear Caliper Piston help ASAP!!!
hey do any of you guys know how to compress the rear caliper piston on the TC??? i tried with a c clamp... and tried turning it clockwise with the two holes on the piston and it isn't working and i need to get back on the road tonight. help is GREATLY APPRECIATED!!!
any ideas??
any ideas??
Last edited by kissmySS08; Apr 16, 2009 at 07:47 PM. Reason: Automerged Doublepost
i had this same problem. you have to take a needle nose pliers and use the grooves on the piston to twist the piston clockwise as you push it in. you basically have to screw it in. i was told this is used so it will come out so you dont have to pull your e-brake out further as your pads wear down
i give up....yeah the ebrake was off and i tried the needle nose... it turned and i was pushing in on it, but it wasnt moving... might just take it to the dealer tomorrow cause they said it'd only be $50 to install them?! thanks though guys
i had my friend come over who owns one and he did his rear pads before... he said you have to twist it like on the SS/SC but we couldn't get it to move, so ill let the dealership mess with it/break it so i dont have to pay to replace it
What's the big deal? Just loosen the bleeder screw, hook up a hose, and push the piston back in. Just make sure to bleed the hydraulic system afterwards. When you push the piston back in, where do you think the fluid is going? To limbo? It's going back through the system and into the ABS pump / master cylinder. Rather than make extra work for yourself, loosen the bleeder screw so the fluid gets pushed outside making your job easier.
Did you know that you're supposed to be able to push the pistons back in by hand (for the normal front calipers). They're not supposed to bind up at all.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
