Hahn RaceCraft Hahn RaceCraft Is a Supporting Vendor of CobaltSS.net
Contacts: EcoBoost ; Hahn Sales
Hahn turbo oil solution question
Old May 4, 2009 | 07:43 PM
08turbo'dSS's Avatar
Here's What the description says:
Cobalt S20G Turbo Oil Solution
The lifeline of your new turbocharger is its lubrication system. Compromise this critical aspect and you won't only have to deal with puddles on the driveway…you may also have to replace a junked turbo! Don’t take chances. This highly-engineered solution has all the right components to make your S20G Turbo a BOLT-ON. That’s right…no need to drop the oil pan and drill the block or pan. We make it so easy you won’t believe the savings in time and hassle!
Exclusive “NO-DRILL” oil drain system
Oil pan stays on engine, no tedious drilling into engine block or pan
Stainless steel Teflon-lined oil feed
All fittings custom-designed for Ecotec engines
100% solution, nothing else to buy!
_______
I'm just trying to figure out how it works and what is it is? Can someone maybe explain this to me?quq
Old May 4, 2009 | 07:48 PM
AcesNEights's Avatar
Its all ur oil lines and fittings u need for their turbo.
Old May 4, 2009 | 07:56 PM
i understand that, but how does it work if there is no oil pan tapping or drilling?
Old May 4, 2009 | 07:58 PM
it drains into where the drain plug should be
tuner923's Avatar
link?
Old May 4, 2009 | 08:07 PM
ok, so there is a replacement drain plug for return line, but what about sending line?
bump...
Last edited by 08turbo'dSS; May 4, 2009 at 08:07 PM. Reason: Automerged Doublepost
Old May 4, 2009 | 08:10 PM
the sending line comes out of the head, theres 3 torx bolts in the back under the header, Im pretty sure they have theirs come from one of those
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
