Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
ott stage 1 boost??
Old Jun 14, 2009 | 08:06 PM
06cobalt racer's Avatar
ott stage 1 boost??
what is everyone boosting with the stage 1 kit? my mods are in my sig and i got to 15 psi and stay there. is that normal?
Old Jun 15, 2009 | 05:13 PM
baltimorebalt's Avatar
Yeah i get to 15 maybe 16. winter i was runnin to 17 right after i installed it but think that was just the cold air
Old Jun 15, 2009 | 05:16 PM
AnthonyCM's Avatar
i'm pushing around 16-17
Old Jun 15, 2009 | 06:43 PM
Cefaln452's Avatar
17 plus
Old Jun 15, 2009 | 10:23 PM
schamsy's Avatar
Originally Posted by Cefaln452
17 plus
I call bs on the + there, up to 17 is normal, unless it is negative 50 degrees. I hit 17 on gm stage 2.
Old Jun 15, 2009 | 10:31 PM
ssyellow's Avatar
but is OTT a 2.8 pulley?? I hit 15 on GM stage 2.
Old Jun 15, 2009 | 11:50 PM
yeah it is a 2.8
Old Jun 16, 2009 | 12:18 AM
ajjaro's Avatar
with meth the boost should be 17-18...?
Old Jun 16, 2009 | 12:23 AM
Sharkey's Avatar
boost is a restriction, you dont want that. airflow is what you want. a byproduct of increasing airflow into an engine with a blower or turbo is pressure. in an engine, restriction is created and thats what causes pressure, or boost.
that being said, boost with X pulley depends on the rest of the mods. having a cat, after market cat or no cat will change boost pressures, same with header and exhaust, sizes. if you had a ported head and intake with the same pulley vs unported you would have less boost, however the same amount of airflow.
Old Jun 16, 2009 | 08:34 AM
ok so having less boost then someone else with the same pulley would be a good thing then?
Old Jun 16, 2009 | 12:31 PM
MP Cobalt's Avatar
I see 15 with GM Stage 2
Old Jun 16, 2009 | 04:57 PM
Cefaln452's Avatar
17 plus hate it or love it... Its all about the mods and engine
Old Jun 17, 2009 | 08:23 AM
stew_pidaso59's Avatar
i top out at 17.5 which really surprises me. I have vibrant header dp with high flow cat and 2.5 catback ottp exhaust. Im not sure why im seeing so much boost on my ottp stage 1.
Old Jun 17, 2009 | 09:04 PM
any ideas why i still have so much restriction to be boosting 17.5
Old Jun 17, 2009 | 09:32 PM
Sharkey's Avatar
less pressure would equal less heat, so in theory yes, but its not going to be noticable between, say, 16 to 17lbs, at least not in our small motors.
Old Jun 17, 2009 | 09:45 PM
right. thanks for your help.
Old Jun 29, 2009 | 12:52 PM
ok so i just got done installing my header and downpipe. now i am barely pushing 12.5 psi?!?!?!?
Old Jun 29, 2009 | 01:09 PM
camaromanss1992's Avatar
exhaust has alot to do with it. on stg2 i was at 16 all day with stock header dp. when i went to CA v2 and 3" catless went down to 12.5 w/ no whine. now that i have a cat its back up to 15.5. put on 2.9 and went back to 16
Old Jun 29, 2009 | 09:44 PM
you have 16 on a 2.9? i only have 12.5 on a 2.8
Old Jun 29, 2009 | 10:07 PM
greygoose08's Avatar
yeah bout 16
Old Jun 30, 2009 | 07:45 PM
i was at 12.5psi on stock pulley as well as with stg2 2.9 and header, 3" catless dp, and catback. it was at 16psi over the winter, approx 15degrees, on same setup but with cat and today when i went wot in second i only hit 15psi or so, 85degrees out.
Old Jun 30, 2009 | 11:00 PM
changed to say 2.8 not 2.9^^^^
well i did a full 2nd gear pull. hit 13.2. it was 67 outside. still seems low to me. what do you guys think?
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
grampss
Sep 27, 2015 08:51 PM
