Nitrous Oxide N20
Nitrous Pressure Gauges
Old Sep 14, 2009 | 12:44 PM
rcmpayne's Avatar
Canada Nitrous Pressure Gauges
Hello All,
So I am finally going spray and had a question about the Nitrous Pressure Gauges. I see some that show 0-30, 0-120 and 0-1600 PSI and I am not sure what I will need as I don’t want to have a gage showing more than needed, for a 5-10lbs Bottle running a 50shot
Making the order Friday still tossed up between the NOS and the ZES kit.
Old Sep 14, 2009 | 05:55 PM
fjordbosun's Avatar
Where are you planning on putting you gauge? 0 to 1500/2000 is most typical to have on your tank, with is the best spot if you running haeter set up, that way you see right away you pressure jumps as you adjust you temp. If you run it under the hood be sure yuo
use one that's designed to be there, (liquid filled). If you plan on going to any drag strip
the track rules may govern that if you have a nitrous gauge on your dash that it be
electronic, meaning there are no nitrous lines running to the gauge inside the passenger area. The might look for that during tech-inspection.
My gauge @ the tank
Last edited by fjordbosun; Sep 14, 2009 at 05:55 PM. Reason: Automerged Doublepost
Old Sep 18, 2009 | 03:22 PM
StreetLC's Avatar
Is that a Harris Speedworks setup?
Old Sep 18, 2009 | 03:26 PM
RedSSBaltSC's Avatar
Edited to make sense :P 0-1600 electrical gauge is what you want.
Old Sep 18, 2009 | 07:50 PM
RA122324's Avatar
Originally Posted by RedSSBaltSC
You need to find out if the kit you want is a high or low pressure kit. Most likely it's high pressure, so the 0-1600 gauge is what you want.
What the hell is a low pressure nitrous kit?
Old Sep 18, 2009 | 09:16 PM
rcmpayne's Avatar
i want it on my A piller in the front so a electric is what i will need.
Old Sep 19, 2009 | 08:14 PM
IDK but I've heard people talk about low and high kits... but the more I think of it, that doesn't really make sense. When I fill my bottle, it's at like 900psi alone, then I use my heater to keep it where I want it (1000psi). I can't find any Nitrous gauges that are measured from 0-30 or 0-120 like the OP said either.
Old Sep 22, 2009 | 01:40 AM
fjordbosun's Avatar
DynoTune bottle and auto heater w/summit racing liquid filled gauge, bit of a hack job on the carpet, I've cleaned it some since the pic was taken.
Old Sep 22, 2009 | 09:36 PM
BillyBboy's Avatar
imo 3 gauge pod looks the best. i still have the bottle mounted bottle pressure gauge but also have the mechanical one as i supplied a picture for you above. here are some pics from the outside if you care about appearance.
Old Sep 25, 2009 | 04:53 PM
rcmpayne's Avatar
do you have the link for the gage as this is exactly what i want. i already have the 3 pod.
going with AF, N2O and not sure for the 3rd yet.
Old Sep 28, 2009 | 07:51 AM
RA122324's Avatar
Good.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
