new flow tru tank
Old Sep 23, 2009 | 02:59 PM
advise's Avatar
new flow tru tank
new tank thanks to euthanasia, what a nice piece with perfect welds, It also has screen so you can add ice
Old Sep 23, 2009 | 03:00 PM
Jn2's Avatar
Jn2
ice floats unless ur running low on coolant a screen isnt needed, but otherwise looks nice
Old Sep 23, 2009 | 03:08 PM
TonyTuna's Avatar
unless your using dry ice.. =)
Well it floats too when it gets smaller
Nice tank, very kewl, still waitin for minez
Old Sep 23, 2009 | 03:37 PM
advise's Avatar
i wonder how long a chunk of dry ice would last in the coolant??
Old Sep 23, 2009 | 03:47 PM
arkkornkid's Avatar
I bet you could wrap it with heat reflective tape to help keep it from soaking up the engine bay temps.
May be overkill though. Anyways, good looking job on the tank.
Old Sep 23, 2009 | 03:48 PM
Bl4des's Avatar
dont put dry ice in you coolant it will build up to much pressure
Old Sep 23, 2009 | 03:53 PM
TonyTuna's Avatar
in the tank or the lines in general? cuz pressure in tank can always be relieved, adjusted, or a fitting can be added so no pressure builds up in tank
Old Sep 23, 2009 | 04:06 PM
advise's Avatar
ya the tank has a pressure valve so it does get air locked, so would the lines build to much pressure
Old Sep 23, 2009 | 04:09 PM
Bl4des's Avatar
idk how bad it would really be but i just just normal ice in my tank i would never put die ice in mine
Old Sep 23, 2009 | 04:14 PM
advise's Avatar
ya i figured dry ice would be better because it doesn't dilute your antifreeze
Old Sep 23, 2009 | 04:26 PM
Bl4des's Avatar
well coolant doesn't cool as well as water does so more water is better
Old Sep 23, 2009 | 04:51 PM
TonyTuna's Avatar
i think dry ice would last longer but blades got a point
Idk, something to try for me when i get the tank but regular ice is a proven thing
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
goaliemo
Sep 28, 2015 01:37 PM
riceburner
Sep 26, 2015 12:57 AM
