Nitrous Oxide N20
no2 25 dry shot
Old Sep 25, 2009 | 01:52 PM
hawkesb3's Avatar
no2 25 dry shot
i plan on running a dry 25 shot with meth on the zzp stage 2... if im running meth would i be able to safely run the dry shot ? also should i tune for the meth and have the timing advanced or should i just use it for the cooling effect and fuel mix with no2 ?
mods are 42s, 3 in pulley, k&n intake, cat less dp, magnaflow catback, zzp pcm
Old Sep 25, 2009 | 02:19 PM
Spins All Day's Avatar
A 25 shot? really?
At least run a 50 shot.
On a dry shot you need to fuel it yourself. So if you are running a 3.0 pulley on 42's with a 25 or 50 shot dry I would be using 60lb injectors.
You need to change to 60lbers before you spray it. That will be enough fuel for a 25 shot and a 50 shot.
A Wet shot adds the fuel for you.
Old Sep 25, 2009 | 02:24 PM
AnthonyCM's Avatar
idk much about N20 but i'd suggest upgrading your injectors i know my buddy had to when he was running his shot
Old Sep 29, 2009 | 01:41 PM
06'Yellow SS/SC's Avatar
spinsallday has the right idea. with a dry shot you want larger injectors than the 42s. 60s is more than enough for a 20 or even a 50.
Old Sep 29, 2009 | 06:50 PM
I this thread is dead but I want to reiterate this just so you make sure you do it right.
If you have a 3.0 Pulley on 42lber and add a 50 shot YOU MUST HAVE AT LEAST 60LB injectors.
Anything over 90% Injector Duty Cycle you are running static.
To be honest I would take your stage 2 Cobalt Ie 3.0 pulley, Intake, Full exhaust, and hit it with a 100 WET SHOT. Have it all tuned on a dyno.
Old Sep 30, 2009 | 04:23 PM
hawkesb3's Avatar
if i am running 42s with stock pulley and i put the 25 dry shot in front of the maf it should be good though right ?
Old Oct 1, 2009 | 04:21 AM
You should be fine with 42's on the stock pulley and a 25 shot.
If I were you I would buy 60's and run a 50 or 75 wet shot @ least.
LSJ's are known for blowing under heavy heat and not enough fuel to the 4th cylinder. Nitrous won't be as bad on the intake temps and will have enough fuel. If you make 220WHP on your setup without the hose I don't see any reason not to hit it with a 100 shot.
Its safe enough to where Gm has a kit that encourages it.
Old Oct 1, 2009 | 08:53 AM
hawkesb3's Avatar
gm has a nitrous kit ? details please ...oh ya and ill be running meth along with the no2... thats why i thought a 25 dry shot would be ok with 42s meth and a 3in pulley running 100 octane
Old Oct 1, 2009 | 01:30 PM
GM Stage 3 kit uses a 50 shot of nitrous.
Therefore your 25 shot doesn't work with it.
Its the GM stage 3 Kit
Old Oct 1, 2009 | 01:38 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i had gm stage 2, 2.9, full bolt-ons, 60 shot. ran 18 bottles through the car like that. then another 4 bottles on 60's, and another bottle on 60's and 75 shot. gm stage 2 and ~50 shot works
Old Oct 1, 2009 | 08:22 PM
Wet shot right?
Cause 2.9 and 42lbers on a 50 dry would be maxing the **** out of your injectors.
Old Oct 1, 2009 | 08:33 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yes wet shot. still working the crap out of the injectors but it never failed
Old Oct 2, 2009 | 11:12 AM
Cigar Hero's Avatar
Go dry with N2O and Propane! Propane runs about 103 octane.
Old Oct 4, 2009 | 10:53 PM
boosting in Ohio's Avatar
NO2= Nitrogen dioxide
N2O= Nitrous Oxide
sorry I'm a Chem major.
Old Oct 4, 2009 | 10:55 PM
burnrubr88's Avatar
omg if your going to use nitrous at least learn the term for it mr no2..........
edit - just saw the post above me. Im with that guy.
newbs..............
Old Oct 31, 2009 | 06:39 PM
LOUD SS/SC's Avatar
Originally Posted by Spins All Day
A 25 shot? really?
yea because if you go with a 50 shot you will bend some exhaust vavles my buddy did with a 50 dry shot
Old Nov 1, 2009 | 04:22 AM
StreetLC's Avatar
Damn....so that means my 100 shot is gona go KABOOM!
Old Nov 1, 2009 | 01:54 PM
LOUD SS/SC's Avatar
yup but depends on your mods
Old Nov 1, 2009 | 07:23 PM
This is terrible information.
Your buddy went with a 50 dry shot, He probably also had other mods, So that means he was around 300WHP.
Let me guess he had 42lb injectors some bolt ons and a 50 shot. Well no **** its going to blow up. There isn't enough fuel at all , PERIOD!!
Even if he was running 60lb injectors he might have been close to 90% IDC.
Dry shots are shitty. Run a wet shot, It adds fuel FOR YOU.
Just because your buddy had NO CLUE what he was doing doesn't mean its going to blow up.
Why are there people making over 350WHP on the stock bottom end?? Cause according to your opinion they should have already bent some valves and ****.
Just because your buddy put a dry shot on his cobalt and didn't know what the hell he was doing doesn't mean everyone else will be the same, Sorry but your example sucks.
I know your buddy doesn't know what hes doing for the sheer fact that he put a dry shot on his car instead of a wet shot. That in itself is ignorant.
If a 50 shot was so bad then why does the GM Stage 3 kit come with a 2.9 pulley and a tune to run a 50 shot. Oh yeah thats right cause its reliable if done right.
Who knows more, You or the engineers at General Motors? Im gonna go with GM. To add more proof of how wrong you are.
88958719 Stage 3 2006 - 07 Performance Upgrade Kit
Take your Cobalt SS to the next level with our Stage 3 Off-Road kit!
The Stage 3 kit consists of the following:
• Smaller, 76mm supercharger pulley
• 2-pass intercooler end plate
• Unique PCM which includes a calibration for the smaller pulley, an adjustable rev limiter, a 100 octane mode, and a nitrous algorithm.
Our Stage 3 kit will take your supercharged Ecotec to a whole new level of performance. Stage 3 takes horsepower output to 248 on 93 octane fuel and to 260 horsepower on 100 octane fuel.
In addition to the power increase, you'll also get an adjustable rev limiter and calibration for a 50 shot of nitrous (nitrous kit not included).
For best power, we recommend also installing a high-flow exhaust.
The PCM is equipped with a user adjustable rev limit from 6750 to 8000 rpm. The rev limit is adjusted by pressing on the throttle pedal with the ignition on and engine off. At about 50% throttle the tachometer will show the current rev limit. Pressing the throttle further will adjust the rev limit in 250 rpm increments. This PCM is also equipped with a control scheme for the equivalent of a 50-horse shot of Nitrous. The PCM will automatically provide the proper spark and fuel for A Nitrous up to 500 rpm below the current selected rev limit when the trigger is activated.
Looks like you're wrong.
Old Nov 2, 2009 | 04:57 AM
StreetLC's Avatar
Well said.....nitrous done right can be very safe. Im running a 100 wet shot on my SS/SC while runing a 2.9 pulley as well as I/H/E/CAI and a heat exhanchanger and ive gone through 3 bottles so far with no problems and a perfect 11.2 AFR.
NITROUS FTMFW!!!!
Old Nov 6, 2009 | 08:32 PM
revhrd4's Avatar
Yeah that was me that had the 50 dry shot man. I ran the GMPP Stage 3 kit but could not make the damn computer work with the nitrous system. had all wires and switches etc hooked up but as soon as the ignition was turned on the nitrous solonoid was clicking on. so just hooked up the n2o the regular way without going thru the gm stge 3 computer. so it took 4-5 runs with the 50 dry untill it BURNED a valve in the motor NOT BEND a valve. Ran to lean at topend a burnt out an exhaust valve. i figured try it since gm says its ok but its not running threw the stge 3 computer. live and learn i guess LOL.
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
How to Guide
57
Oct 15, 2015 11:56 AM
RyGuy
Sep 21, 2015 10:03 PM
yellowsupercharged06
Sep 17, 2015 04:40 PM
