2.0 turbo build
Old Nov 16, 2009 | 01:01 PM
bcss/sc's Avatar
2.0 turbo build
so im at the end of my turbo build and i have a guy coming to tune the car in 2 days,and now my car is draining the battery and not recharging it. i had a fully charged battery and brand new 2.2 alternator what could be doing this?i took the battery and had it checked and recharged.so i hooked it back up and the car is dead no power at all. i can hear a clicking sound coming from under the dash?
Old Nov 16, 2009 | 07:06 PM
Balento18's Avatar
mabe you have a starter issue? If you have a nun stock sound system then check if a amp is staying on
Old Nov 16, 2009 | 07:07 PM
cobaltguy889's Avatar
when you swapped alternators, did you swap plug too? Are you sure you wired it right? I know i had mine backwards and had the same issue
Old Nov 16, 2009 | 07:21 PM
rico's Avatar
ill be turboing my 2.0 lsj soon. if yall would not mind giving me pointers and advice on pm or anything ill apreciate it
Old Nov 16, 2009 | 07:25 PM
well, what questions do ya have?
Whats needed? Ways to run piping?
What kind of setup are you looking at?
Old Nov 16, 2009 | 07:29 PM
bcss/sc's Avatar
Well I have had the car running a few times and when I did the battery came up on the dash.so I shut the car off and then I went to to try and start it again and nothing.I've checked all fulse's but found nothing.when u mean wired the plug do u mean the male end? Or the female end on the alternator?and I don't think the amp came on would have heard it switch on.
Old Nov 16, 2009 | 07:32 PM
1. Did you swap alternators? IE buy an alternator from a 2.2L and put it on your lsj.
2. If you did, you had to cut the old plug off from the lsj alternator, and wire in a new plug for the 2.2L alternator, did you do that?
3. If you did, that means you probably wired them backwards. cut and resolder the two wires except wire them the opposite way you did originally.
Old Nov 16, 2009 | 07:36 PM
rico's Avatar
pmd u. sorry op for stealing this a bit
Old Nov 16, 2009 | 07:41 PM
bcss/sc's Avatar
I have the 2.2 on the car now. I took the plug off the 2.0 and switched it on the 2.2 so that it would plug in to the harness.
Old Nov 16, 2009 | 07:43 PM
ok cool. If your battery light is on, you soldered them backwards. So switch the wires and you should be good to go. It happened to me too.
Old Nov 16, 2009 | 07:52 PM
bcss/sc's Avatar
Ok I'll give that shot.and for the car having no power any ideas?
Old Nov 16, 2009 | 07:54 PM
Either you have a loose battery cable (i know it sounds stupid) or your battery is shot. If it clicks like that, it means that its not gettin enough juice to turn it over. (obviously) Also check the huge red fuse in the trunk on the battery cable
Old Nov 16, 2009 | 08:37 PM
bcss/sc's Avatar
Yes I've done all of that and still nothing .I took the battery in today had it checked and recharged to
Old Nov 16, 2009 | 10:14 PM
ok... few questions
1. Is it a hard click, to the point where the lights shut off and the power turns off and then back on? Oorrr does it click and the power turn off and stay off.
I had my supercharger completely lock up on me. It was to the point where the car wouldn't start, because the crank was stuck. If your tensioner is wrong, or your one of your accessories on the belt locked up, it would cause a loud Click, sounding like the car wanted to turnover but it wouldn't.
If not the above, and its a quieter click, and the power stays off, check your grounds, and check the battery/power terminal under the hood. Make sure both are hooked up, and the power stick/stub/whatever u wanna call it is screwed on tight.
Those are the only things that I can think of off hand that could cause a start like that. I'm going to go home and just peek around my car and see if I can come up with some other ideas.
Old Nov 17, 2009 | 09:04 AM
bcss/sc's Avatar
Car has no power at all just a little click under the dash without trying to turn it over
Old Nov 17, 2009 | 10:09 AM
it sounds like a faulty power connection, or something is shorting out. Did you try jumping the car? I know it sounds stupid....
Idk man, i'm stumped. It sounds like a bad battery connection...
Old Nov 17, 2009 | 11:01 AM
bcss/sc's Avatar
okay i will play around with the battery connection and see and ill check all fuse's again. is there any way of testing or knowing if any of the bigger fuse are done?since u cant really tell.
Old Nov 17, 2009 | 11:12 AM
JapEatr's Avatar
South Central *********
test light, ground the end of the test light and touch the metal prongs on the fues that protrude on the non-business side of the fuse
if it lights on one side and not the other it is popped
Old Nov 17, 2009 | 11:42 AM
bcss/sc's Avatar
I checked battery - and it wouldn't go in factory spot moved it around got power so I'm gonna take the alternator off and post a pic of it andsee if u think I have it wired right?
Old Nov 17, 2009 | 12:05 PM
start the car and see how it runs first. If you still get a red battery light on, then try switching the two wires
Old Nov 17, 2009 | 03:53 PM
bcss/sc's Avatar
yes im still getting the red battery and i moved the wire's around but my Aeroforce gauge is telling me my batterry is almost full and i turned everything on and the gauge goes down a little then right back up
Old Dec 12, 2009 | 11:18 PM
recklessnova's Avatar
battery with the car off hsould be reading around 12 something
battery with the alternator charging it should read 14 something
if your not getting up in the 14 range when car is running its not charging
you should be able to use your gauge to read this if not use a multi meter arbor freight sells one thats 3 bucks I have 4 or 5 of them used to keep one in all my older cars.
Josh
Old Dec 13, 2009 | 09:14 PM
Kennyspec's Avatar
WOW you guys sure like to do things the hard way.
tensioner from a 2.2 $30
weld clutch on LSJ alt $15
40" 5 rib belt $30
not having to **** around splicing wires and having alt charging issues....priceless.
ditch the 2.2 alt, weld clutch, problem solved.
Old Dec 13, 2009 | 10:18 PM
rico's Avatar
got a how to on how to weld the clutch or pics?
Old Dec 13, 2009 | 11:01 PM
Kennyspec's Avatar
remove alt.
remove plastic cap on alt pully.
weld clutch to pully.
reinstall alt.
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 28, 2015 12:51 PM
