Help..
Old Nov 20, 2009 | 01:30 AM
padlock's Avatar
Help..
alright so i realized my passenger side speaker is blown so i was wondering what my options are to replace the two 6.5 inch speakers in the front (might as well do both). I'm a complete noob when it comes to number of watt speakers to get, and all that other stuff, but wiring cant be too complicated so ill handle it if explained
I do have the 7 speaker pioneer system
I obviously only want a speaker that is going to be comparable (or better) to what the pioneers put out, but i dont wanna be paying 200 bucks for speakers.
Any opinions would be a great help! Thanks!
Old Nov 20, 2009 | 03:59 AM
Nighthawk243's Avatar
As far as wattage goes, most decent 6.5's will not even be stressed by the output of the OEM Pioneer system. Luckily for you, mounting is easy since you don't have to hack up the stock brackets or get aftermarket brackets since you have the pioneer setup.
As far as wiring goes, easy as hell. You can easily get front speaker wire harnesses that use the OEM connector so you don't have to splice.
Old Nov 20, 2009 | 04:04 PM
padlock's Avatar
any suggested brands of speakers to get? i dont know if there are clearance issues with certain speakers or not either
Old Nov 20, 2009 | 07:20 PM
There is a good amount of room in the door for speakers, so clearance shouldn't be a problem. As far as brand, it really depends on how much you're looking to spend.
Old Nov 20, 2009 | 08:17 PM
lorenwade's Avatar
Make it easy on yourself. First of all, as already stated you have the 7 Speaker Pioneer system... so the install is super easy and it's super easy to find how to's.
Second, since you already have Pioneer, I'd stick with pioneer.
Third, I suggest you use Crutchfield. Not only do they send you the instructions, but they give you a wiring harness for the cobalt. That means all you do is unplug the old speaker, plug the new wiring harness in, and plug that into the new speaker. Simple and easy for those who have never done this before.
So here you go:
How-To:
If you have door cranks: https://www.cobaltss.net/forums/how-guide-43/how-remove-window-cranks-63173/
The rest of the door: https://www.cobaltss.net/forums/how-guide-43/front-door-speaker-install-w-pics-179593/
Pioneer 6 1/2 Speakers:
http://www.crutchfield.com/p_130TSG1...3R.html?tp=105
http://www.crutchfield.com/p_130TSA6...3P.html?tp=105
Free Wiring Harness:
(free when purchasing speakers on Crutchfield, make sure to specify your vehicle)
http://www.crutchfield.com/p_1207101...Harnesses.html
Suggested Tool:
Door Crank Remover, $6 at auto zone, checker, local car shop.
http://www.rickscamaros.com/product....s-_-IN-50T-_-X
Feel free to PM me if you need help. I've done this many, many times in my car.
Old Nov 20, 2009 | 08:21 PM
Jmarie619's Avatar
first of all.. ive had this happen
take to dealership if you are still under warranty... they should replace your speaker, wires for you etc
Old Nov 21, 2009 | 12:12 AM
EmperorJJ1's Avatar
i would stay away from pioneer door speakers like i would stay away from a rottweiler with rabies
also u want a 2 ohm speaker if possible. the only ones i know of are infinities. also powerbass extreme speakers are 3 ohm
Old Nov 21, 2009 | 02:34 PM
padlock's Avatar
first off lorenwade, it says they dont have the harness i need for my model when i click that link(??)... n i would rather purchase in a store just cuz i dont got those fancy things people call credit cards (i only 17), but not 100% opposed to online i guess. thanks for the help though
and secondly emperor, is there a certain store you can buy these infinity speakers at? or is online the best way to go?
Old Nov 23, 2009 | 05:37 AM
EmperorJJ1's Avatar
best buy has them otherwise check the infinity site for a dealer locator
Old Nov 23, 2009 | 06:28 AM
silver187666's Avatar
i dont have pioneers but my passger side door speeker went out to, why is it the first to go?
evil boost
Nov 4, 2010 08:08 PM
averagewhiteboy
May 27, 2010 01:27 PM
averagewhiteboy
Apr 8, 2010 01:01 PM
06orangebalt
Jan 5, 2010 10:09 AM
