No dash lights
Old Feb 7, 2010 | 10:14 AM
JohnnySasakiMGS's Avatar
Thumbs down No dash lights
I was coming home from North Carolina and it was about 10 pm. I got sick of listening to the crap on XM so I decided to flip through the FM stations and I found a Baptist preacher channel. After listening to the religeous ramblings for a few minutes the radio got all distorted with static and my dash lights went out. Boost gauge, speedo cluster, climate controls and the window buttons all went out. The radio was still lit up but the dimmer switch would not dim those lights and normally it does. They continued to flicker a little bit and work sporadically throughout the night but now they dont work at all. Checked all the fuses and they were fine. Anyone an electronics expert/mechanical exorcist? Its alot of fun driving 600 miles not knowing your speed WOO.
Old Feb 7, 2010 | 10:18 AM
Mindrot's Avatar
Sweet jesus!
Old Feb 7, 2010 | 10:20 AM
Originally Posted by Mindrot
Sweet jesus!
THATS WHAT I SAID!
Old Feb 7, 2010 | 10:22 AM
Mindrot's Avatar
Originally Posted by JohnnySasakiMGS
THATS WHAT I SAID!
Hahaha. I figured I would be the first one to say it. I'll take a stab at it and say Fuse? Ground? I'm no help here
Old Feb 7, 2010 | 11:42 AM
Coblasts's Avatar
I think your bcm might be on the way out,otherwise you have a wiring problem in the dash somewhere.
You didnt smell burning wires did you.?
Do your wipers still work ?
Interior lights.
Why Im saying this is because there is a 50 amp main fuse in the trunk that feeds the bcm which inturn directs power to all the other things that you say dont work.
And for some of these things to quit and and not others and not blow a fuse would mean the bcm would have to be fried or a wirng problem in the dash.
The 50 amp fuse feeds
1)door locks and radio fuse --do they work
2)Rap relay which feeds power window fuse and sunroof fuse---do they work
3)ecm/tcm fuse,this one is all the control modules--if these arent working the cars not running.
Old Feb 7, 2010 | 04:10 PM
Interior lights.
Nope no burning smell. Rearview mirror lights, wipers, door locks, radio, windows, sunroof all work.
Old Feb 9, 2010 | 01:12 AM
Chevycobaltss3's Avatar
COBLASTS knows what he is talking about, he helped me with my issues. But it seems to me that your bcm is done for. But check every thing first, the bcm usually runs about $220 from the dealer with a discount and the flash is around 100$ So if it is the bcm you would know how much the price is to repair it.
Old Feb 9, 2010 | 02:01 PM
DaBuzzard's Avatar
----snip-----
-----snip------
When you say this stuff all went out, do you mean the lights for all this went out or they actually stopped working - can't open windows, no speedo indication, etc?
Side question - are your tail lights (not signal or brake lights) out as well?
Old Feb 9, 2010 | 04:52 PM
Only the lights specified above went out. Gauges and everything still worked correctly.
Old Feb 10, 2010 | 01:50 PM
DaBuzzard's Avatar
Hmmmmm. 4 years old, upstate NY (salt on roads?) - if the fuses are ok, check the underhood fusebox itself - have heard of cases of the board inside corroding and failing.
Long shot but that's all I got......
Old Feb 10, 2010 | 06:08 PM
**** it. I'm trading the car in. If anyone sees a debadged yellow ss with 86kmi+ , DONT BUY IT.
Old Feb 10, 2010 | 08:41 PM
Coblasts's Avatar
Heres something for you.
Those lights all have this splice in common S233
Location is
S233
(CKT 8) In the I/P harness, lower left of the I/P, approximately 5 cm (2 in) from the ambient light sensor breakout
Not sure where that is exactly but a possibility.
And dont over look your dimmer switch.
Maybe you could find someone to let you try theres for a second to see if it is the problem.
You could also try tapping on it.
Old Jan 12, 2021 | 07:33 PM
Brayden Cyphert's Avatar
Hey, did you ever get an answer on this? I’m experiencing the same issue, and checked fuse which all seem to be normal
wvarmyguard
Mar 8, 2010 01:35 AM
h8ter
Jul 19, 2009 10:57 PM
wisemanonice
Mar 2, 2008 05:00 PM
patathSS
Oct 3, 2007 10:20 PM
