throttle body wiring help
Old 04-06-2010, 11:39 PM
08CPE?SS's Avatar
im trying to convert my 6 pin to an lsj 8 pin need help
Old 04-07-2010, 09:01 AM
Coblasts's Avatar
8 Pin
Throttle Actuator Control (TAC) Module Pin
Wire Color
Circuit No.
Function
A
D-GN
485
TP Sensor 1 Signal
B
L-BU/BK
1688
5-Volt Reference-2
C
BK
2752
Low Reference
D
PU
486
TP Sensor 2 Signal
E
YE
581
TAC Motor Control - 1
F
BN
582
TAC Motor Control - 2
G
GY
2701
5-Volt Reference-1
H
BK/WH
1704
Low Reference
6 pin
Wire Color
Circuit No.
Function
A
BN
582
Throttle Actuator Motor Control (2)
B
YE
581
Throttle Actuator Motor Control (1)
C
TN
2752
Low Reference
D
D-GN
485
Throttle Position Sensor (1) Signal
E
GY
2701
5-Volt Reference
F
PU
486
Throttle Position Sensor (2) Signal
Old 04-07-2010, 09:27 AM
Illini_06SS's Avatar
^ Wow, I didn't expect the rewiring to be that straight forward... you just split the two reference wires and then attach them to the appropriate terminal...
Old 04-07-2010, 02:20 PM
dragonkingg5's Avatar
holy crap this came in good timing LOL. been asking Hunterkiller and other people what to do cause i bought the same adapter for the lsj TB. paid like 70 bucks... looks like i should of just rewired my stock one cause i gotta do rewiring anywayz...
so dont worry about two extra 2 wires on the adapter??
i got a pic on my build, click in my sig. the adapter still has 8 wires, thought it would of had 6.
Old 04-07-2010, 03:02 PM
Every wire needs to be hooked up.
Here's a quick diagram of what you need to do:
Old 04-07-2010, 06:17 PM
08CPE?SS's Avatar
i am getting a dtc code for cruise related and my car will randomly slowly raise rpm when im driving in neutral or with the clutch enguaged.
Old 04-07-2010, 06:53 PM
What's the exact DTC code? And have you checked for vacuum leaks? Is this for a supercharge build or are you putting an LSJ TB on your N/A 2.2?
Old 05-12-2010, 10:08 PM
redcobalt07's Avatar
how do you know which pin is A, B, C and so forth
Old 05-12-2010, 10:14 PM
09CobaltLT's Avatar
so wait, you don't even need to buy that 8 pin adapter thing for $70? you can simply rewire it like this?
Old 05-13-2010, 12:38 AM
insylem's Avatar
I should hope you always drive with the clutch engaged, otherwise you wont get power to the wheels....
As for driving in Neutral.. Hmm..... ???
... Or perhaps you mean when you DISengage (press) the clutch, or are in Neutral. And yes my car randomly searches for RPMs too at idle. It's a common problem caused by a dirty throttle valve. I plan on cleaning mine tomarrow acually. There is a howto or sticky about it somewhere on the sight.
Old 11-26-2010, 05:24 PM
rrauter's Avatar
sub'd
DarrenGC
12-24-2021 01:55 PM
dennis69
10-20-2015 07:39 AM
10-13-2015 09:32 PM
SSLOW06
10-01-2015 07:21 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: throttle body wiring help
