Check Engine Light on
Old May 28, 2005 | 01:42 PM
Nightmare's Avatar
I got a 05' Colalt LS only had it less then month. I was parked at a 7-11 got in tired to start my car and it didnt start. I tired 3 times no luck so I waited 5 mins then tired again.
I Look at my handbook said tried pushing petal to floor then start. It worked it started up but now my check engine light is on. My service center is close for weekend and monday wonder if it still safe to drive into monday when I can get it checked out.
Old May 28, 2005 | 02:40 PM
brianfcp's Avatar
Wow, I dont know what to say, you barely had the car, and its giving problems like that already...
Good luck though.
Old May 29, 2005 | 11:46 PM
rm25x's Avatar
my light has been on for a couple weeks now. It will be fine to drive till you can take it in.
Old May 30, 2005 | 12:03 AM
MarcS's Avatar
The Stig
It seems quite a few people have experienced the CEL warning. Probably an electrical problem. In my cavalier I would get it every time it rained.
Old May 30, 2005 | 01:21 AM
homewrecker's Avatar
If it starts to flash though stop driving the car.
Old May 30, 2005 | 05:56 AM
brianfcp's Avatar
So this problem isnt related to the driver's habits? But instead its the fault of the manufacturer? Ok, now I know what to look out for.
Old May 30, 2005 | 09:10 AM
plyboy-illest's Avatar
you got roadside assit so se it if your not too sure if it safe to drive
Old May 30, 2005 | 10:54 AM
Nightmare's Avatar
Well I think I fixed it on my own seems it on a showing AC wiring line. They did a craping wiring job on my car. My light is out now then had a friend hook it up on a computer check or any problems and he found none.
Old May 30, 2005 | 11:26 AM
tx05cobalt's Avatar
theres actually a recall for some problems in the a/c wiring when out side temp reaches 70F or above. The wires will surge a fry one of the sensors.
Old May 30, 2005 | 02:12 PM
moxjake's Avatar
Can you give us a link to that recall notice? I cant seem to find it on the ODI.
Old May 30, 2005 | 06:19 PM
rm25x's Avatar
I will stop driving the car when it no longer runs. Hope that day comes soon.
Old Jun 1, 2005 | 06:16 PM
Maven's Avatar
It looks like this....not all cobalts are involved:
A/C System Wiring or Dual Stage Airbag Module Wiring #05034 - (May 12, 2005)
05034 -- A/C SYSTEM WIRING OR DUAL STAGE AIRBAG MODULE WIRING
2005 CHEVROLET COBALT
2005 PONTIAC PURSUIT
Condition
Certain 2005 Chevrolet Cobalt and Pontiac Pursuit vehicles have one of two conditions, 1) the steering column mounted airbag module wiring may be reversed. The driver's air bag will deploy under the same conditions (see "When Should An Air Bag Inflate?" in your owner's manual) and the vehicle meets the occupant protection requirements of the Motor Vehicle Safety Standards. In the event of a moderate frontal impact, however, the airbag would deploy fully instead of at the reduced level described in your owner's manual, or 2) vehicles equipped with a 2.2L engine (L61) and air conditioning (C67), voltage spikes from abnormal fan switching can damage the air conditioning pressure sensor transducer, resulting in a loss of air conditioning. Damage is more likely to occur if the abnormal fan switching occurs when the vehicle is being driven in city traffic and when the outside temperatures are 70 °F (21 °C) or higher. The spikes can also cause the engine to operate in a reduced power mode. If this occurs, the Driver Information Center will display "ENG PWR REDUCED", and the maximum throttle opening will permit a speed of about 30 mph (48 km/h).
Correction
Dealers are to 1) modify the circuitry to the airbag module, or 2) install wiring to isolate the voltage spike.
Vehicles Involved
Involved are certain 2005 Chevrolet Cobalt and Pontiac Pursuit vehicles built within these VIN breakpoints:
Year
Division
Model
From
Through
2005
Chevrolet
Cobalt
57500350
57584601
2005
Pontiac
Pursuit
57500219
57584526
Dear General Motors Customer:
This notice is sent to inform you that General Motors is conducting a customer satisfaction program that affects certain 2005 model year Chevrolet Cobalt and Pontiac Pursuit vehicles.
We have learned that your vehicle may have been built with one of two conditions, 1) the steering column mounted airbag module wiring may be reversed. The vehicle meets the occupant protection requirements of the Motor Vehicle Safety Standards and the driver’s air bag will deploy in crashes of the same type and severity. In the event of a moderate frontal impact, however, the airbag would deploy fully instead of at the reduced level described in your owner's manual, or 2) vehicles equipped with a 2.2L engine and air conditioning, voltage spikes from abnormal fan switching can damage the air conditioning pressure sensor transducer, resulting in a loss of air conditioning. Damage is more likely to occur if the abnormal fan switching occurs when the vehicle is being driven in city traffic and when the outside temperatures are 70 °F (21 °C) or higher. The spikes can also cause the engine to operate in a reduced power mode. If this occurs, the Driver Information Center will display "ENG PWR REDUCED", and the maximum throttle opening will permit a speed of about 30 mph (48 km/h).
What We Will Do
Your GM Dealer will either modify the circuitry to the airbag module or install wiring to isolate the voltage spike, whichever is the appropriate repair. This service will be performed for you at no charge .
Ive done a bunch of these already if youve got the 2.2 and A/c it takes all of about 9 minutes.....if you DONT have the 2.2 AND A/C its more like 1/2 hour
Old Jun 1, 2005 | 06:30 PM
tx05cobalt's Avatar
when that damn engine pwr reduced message comes on you will wish you werent driving the car.... Happened to me and trust me It was not a fun drive to the dealer.
Old Jun 1, 2005 | 08:36 PM
BJC's Avatar
BJC
Just wondering when they say "fan" do they mean the engine fan or the AC/heating fan (or would that be called the blower)?
Old Jun 2, 2005 | 03:18 PM
tiny's Avatar
so if my car meets the cars involved, should i get it done, or wait and see if anything happens
Old Jun 2, 2005 | 03:22 PM
tx05cobalt's Avatar
I would go ahead and get it done.. My car was in the shop 3 times for this before they put that new harness in. So I actually had it done before the recall. First time air just quit working as in it would not blow cold. Second time I got the eng pwr reduced but hey atleast the air was working while trying to navigate through city traffic at a speed comparable to a horse drawn buggy. For the last time the air quit working. However since the new part I have had no troubles.
Old Jun 3, 2005 | 08:19 AM
Maven's Avatar
"fan" is engine coolant/A/c Condenser/intercooler radiator fan......'blower' is the fan in the car that blows on your face.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Sep 26, 2015 06:44 PM
