Header question.
Header question.
Will the ZZP header work on a 2.2?
Is the coating protective against heat/rust, will it burn or flake off?
Any idea on gains it if would fit the 2.2?
Thanks alot...
Thanks alot...
Thanks alot...
Thanks alot...
Originally Posted by DTM2188
I'm not sure if it will fit the 2.2l or not. However, the one that is labeled "Ecotec" header is not ceramic coated so it won't protect well against heat/rust and may flake. The "TOG" header on their site is ceramic coated and should protect well against those elements.
http://zzperformance.com/cobalt_ion/...ts1.php?id=543
I also read on here somewhere that the TOG header was junk...
Well it says "High temp satin coating" so I was wondering if this would have the same affect as ceramic coating.
Any idea on the size of the collector? Is it 3in like the ZZP? If so that would probably be overkill putting it on my 2.2 knowing the pipe with the cat isnt 3in?
Yea the TOG header also has the 3in. collector. Allshot, how do you like your ZZP header and more so the downpipe? Sound quality? Performance?
Originally Posted by Allshot
I like it alot actually. The butt dyno feels really good. The header and downpipe are raspy in the lower rpm range but once you hit like 4k it sounds really nice and deep. If you go WOT in second to redline it sounds like a beast. Id have to give ZZP
z28addiction
Sep 28, 2015 12:03 AM
