ZZ Performance ZZ Performance is a proud Supporting Vendor
Header question.
Old Aug 23, 2006 | 12:17 PM
1SloBowtie's Avatar
Header question.
Will the ZZP header work on a 2.2?
Is the coating protective against heat/rust, will it burn or flake off?
Any idea on gains it if would fit the 2.2?
Thanks alot...
Old Aug 26, 2006 | 10:13 AM
1SloBowtie's Avatar
Anyone there!?!?!?!?
Old Aug 26, 2006 | 10:18 AM
DTM2188's Avatar
Thanks alot...
I'm not sure if it will fit the 2.2l or not. However, the one that is labeled "Ecotec" header is not ceramic coated so it won't protect well against heat/rust and may flake. The "TOG" header on their site is ceramic coated and should protect well against those elements.
Old Aug 26, 2006 | 07:22 PM
1SloBowtie's Avatar
Well it says "High temp satin coating" so I was wondering if this would have the same affect as ceramic coating.
http://zzperformance.com/cobalt_ion/...ts1.php?id=543
I also read on here somewhere that the TOG header was junk...
Old Aug 27, 2006 | 12:23 AM
DTM2188's Avatar
The high temp satin coating won't really help out with keeping it from rusting and excessive heat wear. The TOG I haven't really heard too much about at all. I know one member said it was good and another said it wasn't. So I'm not sure, I may actually be getting myself though.
Old Aug 27, 2006 | 12:19 PM
1SloBowtie's Avatar
Any idea on the size of the collector? Is it 3in like the ZZP? If so that would probably be overkill putting it on my 2.2 knowing the pipe with the cat isnt 3in?
Old Aug 27, 2006 | 12:22 PM
Allshot's Avatar
I checked out my zzp and it still has the coating that they put on it and it hasnt flaked at all. The TOG had fitment issues but if you get the adapter flange it will work.
Old Aug 27, 2006 | 07:53 PM
DTM2188's Avatar
Yea the TOG header also has the 3in. collector. Allshot, how do you like your ZZP header and more so the downpipe? Sound quality? Performance?
Old Aug 27, 2006 | 07:57 PM
Nickc84's Avatar
What kind of performance Will headers give you?> is there any Dyno increase in HP-TQ with a CAI
Old Aug 27, 2006 | 08:06 PM
DTM2188's Avatar
Headers are about 7-10 HP and CAI are about 5-8 HP.
Old Aug 27, 2006 | 08:15 PM
Nickc84's Avatar
Not bad
Old Aug 28, 2006 | 12:06 PM
Allshot's Avatar
I like it alot actually. The butt dyno feels really good. The header and downpipe are raspy in the lower rpm range but once you hit like 4k it sounds really nice and deep. If you go WOT in second to redline it sounds like a beast. Id have to give ZZP
Old Aug 28, 2006 | 07:42 PM
DTM2188's Avatar
Thanks for the info. I may be getting there header.
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Bohb
Sep 27, 2015 09:11 PM
