This is new, need some serious help
Old Aug 30, 2006 | 02:53 AM
TheYellowSS's Avatar
Ok before i had the clutch installed by the dealer, i was feeling some serious power from the injectors and pulley, and my fuel eco was like 18 19 mpg. Now after clutch install, same parts are still there injectors and 2.8 pulley. but the car feels stock, and my fuel eco sky rocketed. i drove an hour today and it hit 28 mpg, 28 mpg ok when ur stock, not with 42 lb injectors. So i need some help to figure out what they did. I dont know if they tryed to mess with the pcm cause my rev limetr is still set at 7 grand and the car is running fine. Could it be that the clutch just isnt broken in yet and it robbing me of hp untill its broken in. What else could they have done. Im at a loss for words after everything ive been through so far.
Old Aug 30, 2006 | 03:20 AM
memphisr24's Avatar
hmm...idk, I have 42 lb injectors with a 2.8 pulley and exhaust and my gas gauge tells me 35-38 mpg. But then again, I do about 85% highway driving. Maybe you haven't been beating on your car lately as much as you were before, or maybe you reset the gas gauge.
I can't explain the power loss though...That's strange. Unless the clutch doesn't fully disengage, now that would be a problem.
Old Aug 30, 2006 | 12:36 PM
hmm, i dont know
Old Aug 30, 2006 | 12:45 PM
Dustin's Avatar
Maybe they replaced your injectors with the stock ones
Old Aug 30, 2006 | 12:51 PM
joeworkstoohard's Avatar
well... heres a few theories....
either the clutch you've got on there is WAY heavier than the stock one and it's robbing power... which is hard to fully believe...orr...
you've been driving like an old lady to break in the clutch and the car has been relearning it self and has, therefore gotten "used" to lower loads and easier driving.
try this. getting onto a highway, drop it in 2nd and do a nice WOT pull to highway speeds.... get off and do it again. it will prolly give you a small amout of your power back... and just drive with a lot of throttle action.
also, you could just pull the battery, let the ECM go back to baseline tuning and take her for a ride.
this is all assuming that the car is otherwise running fine and there isn't someting "wrong" that was damaged at the tranny shop.
im about to go check
Old Aug 30, 2006 | 12:55 PM
Ljavy17's Avatar
7k redline + stock injectors = BAAAAAM
Old Aug 30, 2006 | 01:10 PM
yeah the injectors or still there
so maby its the computer having not learned it yet
i just reset the battery and about to go get some bk lol, ill give it a try
Old Aug 30, 2006 | 01:12 PM
they f'd up my intake to, i mean its shot. there are nicks dents and scratches everywhere. it looks horrible
Old Aug 30, 2006 | 01:13 PM
06blackg85ss's Avatar
unless they reflashed your car and erased the tune
Old Aug 30, 2006 | 01:18 PM
see at first thats what i thought, but if they did they it would be running like complete ****, and the 7 k redline wouldnt be there
Old Aug 30, 2006 | 01:22 PM
true... I guess you just gotta drive around til the car gets "used" to the stuff again
DarrenGC
Forced Induction
Jan 2, 2016 09:10 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
dennis69
Sep 28, 2015 02:16 PM
