Stage 2 upgrade questions
Old Aug 21, 2006 | 07:38 PM
SS SCHGD's Avatar
We had stage 2 installed on one of our cars on friday, and it's running great, but we asked to have all the removed parts put in the car. They put them back in the box, (I forgot to check for the special bits though) but the Old pully has been badly bent, Should I go back and request they get me a new one? or is there no way to get it off without bending it?
Thanks
Old Aug 21, 2006 | 07:41 PM
GeoChevyCobalt's Avatar
get a new one. Mine came off fine. A dealer did the install too. I would rease holly hell with them till you get the bits and a new pully.
distillion's Avatar
they bent my stock pulley and broke one of the bits, morons.
Old Aug 21, 2006 | 08:04 PM
SS SCHGD's Avatar
should they replace what they broke? I believe so, but am not positive....
Old Aug 21, 2006 | 09:28 PM
stonny9's Avatar
Yes They Should. They Have The Tools So The Job Should Be Done Right.
Old Aug 22, 2006 | 06:24 PM
RiotGirl587's Avatar
can u put the stage 2 stuff in ur self? like i have a shop to use when i want.
Old Aug 25, 2006 | 11:33 PM
GTPUSER's Avatar
Just rent a pulley puller from ZZP or Intense, but you will have to go do a dealership for to get the pcm reprogrammed though.
Old Aug 25, 2006 | 11:43 PM
Asphalt Assault's Avatar
Thanks
Bent pulley. Man sounds like the hammered it off. I would check to see if they had a proper puller/press. if they dont you coould have supercharger problems in the future.
Broken bits? cant these techs read? 15lbs torque on the bolts. I am guesing that they may have put it on super tight.
good luck.
Old Aug 25, 2006 | 11:45 PM
I did it in my garage with no air tools. but let me tell you the pulley is easy off. putting the hub on is not an easy feat. I had to get a second person and then three wrenchs while pressing the hub on.
Old Aug 26, 2006 | 07:36 PM
DrkknightSS99's Avatar
Thanks
Yea they broke it, they should fix it. BTW where did u go get yours done at?
Old Aug 26, 2006 | 08:10 PM
an0malous's Avatar
FYI GM install = stage 2 covered under standard 3 year warranty
home install = 12 months warranty.
this is from the mouth of a GM district parts manager when i asked him to clarify the stage 2 warranty.
Old Aug 26, 2006 | 09:26 PM
Mellow Yellow's Avatar
What is the deal with taking these pulleys off ? I pressed the shaft out in 5 sec. and pressed the new hub on in 10 sec.after supporting the shaft . I don't know what these dealers are doing. This the easiest engine upgrade in history. They say it won't void your warranty but if you had an issue with the engine related to the stage 2 components you will probably have a fight on your hands.
Mellow Yellow
06 SS/SC
Stage 2 with 2.8"pulley
Old Aug 26, 2006 | 10:12 PM
FYI - my dealer will cover. they know where the kit is. besides a belt or pulley wont fail. and touch would I have never had an injector fail on me. so I would do it. and on top of that I have bumper to bumper 6 year 100,000KM warranty. your source knows ****. I have met guys who told me the GM rep says no warranty on the car if GM Stage 2 is on the car. bunch of BS. there has to be proof that the car is damaged because of a modification before warranty is denied and a Stage kit is registerd to the VIN. GM can tell you which cars have the stage kit, when it was put in, and when the kit was put together for quality control. Your guy is a "Parts Manager", he didnt write the warranty. no offense but I smell **** and I think you stepped in it.
Old Aug 26, 2006 | 10:21 PM
Mellow Yellow
06 SS/SC
LOL dont tell me you used a hydraulic press....LOL. if you did good luck with your supercharger. you need proper press so if does not put load on the shaft to not damage internals (bearings, etc.) either way I used the proper manual press that is build for this purpose. I had the charger off the car and pulled the hub off in 30 minutes only. going on was a challenge just due to a minor hiccup with the puller/press I had. once I figured it out the new hub was on in 5 minutes and charger was back on the car in 15 minutes. change it out in under an hour and inexperienced first timer. injectors took 30 minutes. if you have a clean engine it would go faster. I took some extra time to get dirt from falling in. all in all it was a 1 and a half hours to do the job. It took the dealer longer to do the reflash cause they did not ever do it before.
Old Aug 27, 2006 | 05:46 PM
SS SCHGD's Avatar
they told me that the old hub would be unusable even if they had takken it off and not broken it....ugh. oh well, who's going back...lol
Old Aug 27, 2006 | 06:08 PM
stonny9's Avatar
BUt u would still have the potential to sell it to someone if it was still good. I would request at least 50% of what the pullie would cost new from the dealer.
Old Aug 29, 2006 | 05:29 PM
BEWARE second hand stag kits !!
Beware second hand stage kits !!!! I purchased a stage 2 kit from Ebay last week from a guy in Edmonton Alb. He had it installed at the dealer and then removed it to sell. I installed it myself and went to the dealer to get the ECU flashed. The dealer called the tech line and the they told the dealer that once the code is matched to a vin number it cannot be reused ever. The VMI code for the computer is vin locked to that specific car only. I put the original injectors back in the car with the 2.8"pulley and it is running very well but that is not what I paid $550 dollars for. Lets face it , the parts cost F#$% all for these kits , GM is making a killing ripping people off. I've bought GM all my life but maybe it's time for a change.
Pissed Off
06 SS/SC
Old Aug 30, 2006 | 06:58 PM
SS SCHGD's Avatar
eh, it doesn't matter, I would choose to go to a different hub when I pull the Supercharger and install it on the cavalier....(this is a ways off, waiting to see about the whipple)
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
