stock exhaust needs to be cut for corsa exhaust????
Old Sep 8, 2006 | 10:59 AM
2fastSS's Avatar
Hey all i have the corsa exhaust and was looking at the instructions and what not and saw that they say you have to cut the stock exhaust?? am i right here??
reason im asking is because if so then there really wouldnt be any need to keep my factory exhaust,
also if it is meant to be cut then i dont see how its a REAL bolt on....
idk just someone clarify for me
thanks
Old Sep 8, 2006 | 11:05 AM
joeworkstoohard's Avatar
it is bolt on. the old is just not bolt off... it is installed before the rear crossmember by gm. if you don't mind dropping half the rear suspension you can forgo the cut.
Old Sep 8, 2006 | 11:09 AM
JRANGER's Avatar
ya what he said. Your new exhaust will bolt right on. After you remove the old one which requires the cut to be removed. You should be able to sell the old one to a LS/LT guy. I know I bought one
Later
Old Sep 8, 2006 | 11:22 AM
2fastSS's Avatar
so how much you think i would be looking at for install if i take it somewhere to get done??
Old Sep 8, 2006 | 11:23 AM
OniMirage's Avatar
an hours labor
edit: thats only if it is on a lift not ramps
Old Sep 8, 2006 | 11:25 AM
2fastSS's Avatar
ok sounds good ill prolly go get that done here soon then... thanks for the help bro
Oct 15, 2015 05:11 PM
717ssbalt
Oct 2, 2015 04:01 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
