Rear brake conversion
Old Jun 24, 2005 | 12:04 AM
Jettagls00's Avatar
Has anyone considered a rear disc brake coversion for the non SS cars? I have been kicking the idea around and have asked a couple people at the dealer and I see no reason why this can't be done. Any suggestions or comment would be nice. Thanks in advance.
Old Jun 24, 2005 | 12:49 AM
MarcS's Avatar
The Stig
It's doable but expensive. Unless you're using your car for autocross I'm not sure it would be worth it.
Old Jun 24, 2005 | 10:50 AM
celicacobalt's Avatar
i am really looking into doing this as well it will look 10x better and help stopping distance as well so it would be worthwhile to do
Old Jun 25, 2005 | 10:06 AM
brianfcp's Avatar
wow, thats such an expensive upgrade. the non SS cars arent even worth that kind of work. If i were you, spend that kind of money and get a turbo kit or something, the brakes are good enough.
Old Jun 25, 2005 | 11:06 AM
ssstraub's Avatar
90% of the stopping force comes from the front brakes. I don't think it's worth the hassle.
Old Jun 27, 2005 | 10:30 AM
Nightcrawler's Avatar
Agreed.. Rear brakes don't do much.
Old Jun 27, 2005 | 09:52 PM
Jettagls00's Avatar
After doing some research it doesn't look like it is going to be that easy. I was planning on just getting a set of rears off of the SS but the bolt pattern on the SS is 5x100 and the LS coupe is 4x100 so unless i can get a 4 bolt rotor that is the same size i will have to wait for an aftermarket kit. Thanks to everyone for the replies.
Old Jun 27, 2005 | 11:52 PM
detrini's Avatar
rsm has a converson kit for cobalt
http://www.rsmracing.com/catalog.htm
Old Jun 28, 2005 | 01:54 PM
that conversion looks like its only for an ss since its a 5 bolt pattern, we need it for the ls in the back
Old Jul 24, 2005 | 11:47 AM
05OrangeSS's Avatar
SSBC has already made a rear disc conversion for the cobalt LS. GM sent us a car that they wanted rear disc brakes on. The kit for the LS is already done......front and rear disc, while the kit for the SS is pretty much all done as well. When the SS kit goes on sale i can let you guys know, as for the LS kit I would call to find out about it...check out www.ssbrakes.com for the phone number.
Old Oct 16, 2006 | 06:24 PM
biniecki's Avatar
I am interested in doing this as well and actually did a search. I see the kits on the vendors sites but it always just looks like rotors and calipers. I want to know in detail what is involved with a conversion kit. Also would you be able to swap a rear setup off of a cavi or possible a G5. Not sure what the brake options are on it.
Old Oct 16, 2006 | 07:48 PM
Halfcent's Avatar
I'm old school
It's like "resurrection of the dead threads" week here. Anyway, the kits come with mounting brackets that convert your mounts to hold a caliper instead of a drum. It's basically a simple bolt on. The only messy part is the brake line bleed.
Old Oct 16, 2006 | 09:26 PM
05OrangeSS's Avatar
here, Ill post a list of EVERYTHING you get with the kit.......
A22115 |clpr assy 54mm with | 1| ||06018 |HHCS M12-1.75 x 55mm| 4|
A22116 |clpr assy 54mm with | 1| ||2110 |pin cotter 7/64 x .7| 2|
I |install instructions| | ||1811 |ret flex ln horsesho| 2|
A1209-5 |brkt p/b spcl Cobalt| 2| ||2102-M |wshr seal copper met| 4|
A2408D |spcr tubular .500-ID| 4| ||S23105WP |rtr sltd/pltd Cobalt| 1|
0619 |bolt slider GM wide | 4| ||S23106WP |rtr sltd/pltd Cobalt| 1|
14335S |hose flex 11 ISO blk| 1| || | | |
1211A |clevis pb cbl adpt U| 2| || | | |
2153 |pin clevis 5/16 x .7| 2| || | | |
1820-M |banjo bolt M10-1.5 x| 2| || | | |
A24443 |brkt clpr mtg rear l| 2| || | | |
10113 |pad,D154,z-rated,ext| 1| || | | |
A24431 |mtg brkt clpr Colora| 2| || | | |
06015 |nut flange M12-1.75 | 4| || |
That's the part numbers......so yes you get EVERYTHING you need....
Old Oct 16, 2006 | 09:35 PM
Rangerondubz's Avatar
SS cars have a 5x110 bolt pattern, not 5x100
Old Oct 16, 2006 | 10:45 PM
biniecki's Avatar
I assumed that the kits would include everything. I just want something to show me what to do like a how to or an example from another car so that I know what I would be getting myself into and also look into other options for parts that may be cheaper like getting parts from a cavi or something.
Old Oct 16, 2006 | 11:01 PM
05OrangeSS's Avatar
The kit comes with instructions, and pics of the install as you go. I highly doubt that anything from a cavi would work on the cobalt. Also if you have problems there is a tech line that can assist you. Im sure, as long as you have basic knowledge, that the install would be fairly straight forward and take maybe a day, at most. The kit number is A163-7 and the front is A163-6. You can also get those powdercoated too......
Old Oct 16, 2006 | 11:02 PM
05OrangeSS's Avatar
What was the point of posting that???
Old Oct 16, 2006 | 11:19 PM
EvlPeanut's Avatar
Actually, drum brakes have much better stopping power than Disc. The only advantage of disc to drum (aside from looks) is they cool faster, and like somebody said, unless you're going to be doing some serious autocrossing, its not worth it. The reason GM puts the drum on the base cars is because, the only way you can get equivilant stopping power to the drums is with larger discs an calipers, and since the base only have 15" wheels, larger discs and calipers will not fit.
Old Oct 16, 2006 | 11:27 PM
tonio5555's Avatar
If you want better stopping power for the street I'd just pick up the GMPP Rotors and some decent pads for the front and you'll be set.
Old Oct 16, 2006 | 11:30 PM
EvlPeanut's Avatar
ditto.
Old Oct 17, 2006 | 12:33 AM
biniecki's Avatar
well i have upgraded to 17" wheels and would like to upgrade but the cost for the kit seems a bit pricey. I thats why I am wondering about other options. However if i did the conversion i wouldnt be able to use my 15's for winter tires
Old Oct 17, 2006 | 12:36 AM
Red06LS's Avatar
I thought of that too but if i was gonna spend that kind of money i would just upgrade the front ones.
Old Oct 17, 2006 | 07:45 PM
05OrangeSS's Avatar
Im sure if you shop around on the vendors on the forum here you could work out SOME kind of deal to get it a bit cheaper. Or just call the company directly, they will probably try to sell it to you at retail, but who knows. PM me for some info.
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
