Rear brake conversion
Has anyone considered a rear disc brake coversion for the non SS cars? I have been kicking the idea around and have asked a couple people at the dealer and I see no reason why this can't be done. Any suggestions or comment would be nice. Thanks in advance.
After doing some research it doesn't look like it is going to be that easy. I was planning on just getting a set of rears off of the SS but the bolt pattern on the SS is 5x100 and the LS coupe is 4x100 so unless i can get a 4 bolt rotor that is the same size i will have to wait for an aftermarket kit. Thanks to everyone for the replies.
SSBC has already made a rear disc conversion for the cobalt LS. GM sent us a car that they wanted rear disc brakes on. The kit for the LS is already done......front and rear disc, while the kit for the SS is pretty much all done as well. When the SS kit goes on sale i can let you guys know, as for the LS kit I would call to find out about it...check out www.ssbrakes.com for the phone number.
I am interested in doing this as well and actually did a search. I see the kits on the vendors sites but it always just looks like rotors and calipers. I want to know in detail what is involved with a conversion kit. Also would you be able to swap a rear setup off of a cavi or possible a G5. Not sure what the brake options are on it.
It's like "resurrection of the dead threads" week here. Anyway, the kits come with mounting brackets that convert your mounts to hold a caliper instead of a drum. It's basically a simple bolt on. The only messy part is the brake line bleed.
A22115 |clpr assy 54mm with | 1| ||06018 |HHCS M12-1.75 x 55mm| 4|
A22116 |clpr assy 54mm with | 1| ||2110 |pin cotter 7/64 x .7| 2|
I |install instructions| | ||1811 |ret flex ln horsesho| 2|
A1209-5 |brkt p/b spcl Cobalt| 2| ||2102-M |wshr seal copper met| 4|
A2408D |spcr tubular .500-ID| 4| ||S23105WP |rtr sltd/pltd Cobalt| 1|
0619 |bolt slider GM wide | 4| ||S23106WP |rtr sltd/pltd Cobalt| 1|
14335S |hose flex 11 ISO blk| 1| || | | |
1211A |clevis pb cbl adpt U| 2| || | | |
2153 |pin clevis 5/16 x .7| 2| || | | |
1820-M |banjo bolt M10-1.5 x| 2| || | | |
A24443 |brkt clpr mtg rear l| 2| || | | |
10113 |pad,D154,z-rated,ext| 1| || | | |
A24431 |mtg brkt clpr Colora| 2| || | | |
06015 |nut flange M12-1.75 | 4| || |
That's the part numbers......so yes you get EVERYTHING you need....
I assumed that the kits would include everything. I just want something to show me what to do like a how to or an example from another car so that I know what I would be getting myself into and also look into other options for parts that may be cheaper like getting parts from a cavi or something.
Originally Posted by celicacobalt
i am really looking into doing this as well it will look 10x better and help stopping distance as well so it would be worthwhile to do
well i have upgraded to 17" wheels and would like to upgrade but the cost for the kit seems a bit pricey. I thats why I am wondering about other options. However if i did the conversion i wouldnt be able to use my 15's for winter tires
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
