Nitrous Oxide N20
2.4 NX Questions
Old Sep 18, 2006 | 05:56 PM
articzap's Avatar
2.4 NX Questions
Since we know that the 2.4 can handle some decent power thanks to the folks at hahn making the turbo kit, what size shot can be run on the 2.4? 50? 75? What are some precautions to look out for? My friend wants to spray his car and we just want to make sure we cover all the bases.
Old Sep 19, 2006 | 12:08 AM
bigworm's Avatar
https://www.cobaltss.net/forums/show...&highlight=2.4
Old Sep 19, 2006 | 03:23 AM
IonNinja's Avatar
I would stop at a 75 shot just to be safe
Hahn has takin the Ecotec to +300whp but that was with boost, nitrous has a much stronger hit on the bottom end so you may not be able to reach those power levels on the 2.4 with a large shot without breaking something
Old Sep 19, 2006 | 11:23 AM
articzap's Avatar
My friend wants to run a 75 but we want to make sure it'll be safe enough. He's taking many precautions when we wire it up, including the main on/off switch, window switch, wot switch, and a a/f ratio switch that if it were to go lean it'd cut out. Plans also include remote bottle opener, bottle blanket and a bottle gauge in ss/sc piller. The main thing is we don't want to blow up the car. Were looking to have some fun and hopefully run with some stage ss/sc's on the 75 shot but who knows. Keep the comments coming.
Old Sep 21, 2006 | 03:41 AM
IonNinja's Avatar
you should be fine with your current plans
as long as you aren't pushing it with a large shot 100+ then you shouldn't have any issues
Old Sep 21, 2006 | 11:43 AM
articzap's Avatar
My friend only plans on running a 75 shot thats it. Should he get 1 step or 2 step colder plugs?
Old Sep 22, 2006 | 01:24 AM
bigworm's Avatar
buy both, along with a good scanner.... juice and look for KR, if you get high numbers (3+) go to the next colder step... also you should be looking at a 30-35 gap depending on your afr..
Old Sep 22, 2006 | 01:26 AM
articzap's Avatar
scanner? kr? we do plan on getting a wideband
Old Sep 22, 2006 | 04:29 AM
IonNinja's Avatar
KR = knock retard
most here run 2 step colder plugs
I will be starting with NGK BKR7E-11 gapped @ .035 and see how the car runs...
Old Sep 22, 2006 | 12:37 PM
articzap's Avatar
How do you monitor KR?
Old Sep 22, 2006 | 12:58 PM
Sp00ner's Avatar
You should pick up some tuning info and tools before you attempt this, otherwise you're asking for a blown motor or pistons...
You need a wideband A/F gauge.
You need an Interceptor, or HP Tuners scanner for knock and logging purposes.
Old Sep 22, 2006 | 01:41 PM
slowion2's Avatar
It's good to have a wideband, but it's not necessity <sp>
If you're overly concerned, an interceptor is a good investment to monitor things like Knock and such.
the 2.4 is built strong enough to take the 75 shot in stride, just take the proper precautions (colder plugs i.e. 1-2 step, window switch, WOT switch, at least 91-93 octane fuel, proper jetting, etc)
Old Sep 22, 2006 | 02:15 PM
articzap's Avatar
This is a slow piece together so right now we got the ss/sc pillar on its way, a nitrous pressure gauge for the pillar, and prob going to get an inceptor. You think thats enough gauges or should we spare for the A/F too?
Old Sep 22, 2006 | 02:27 PM
slowion2's Avatar
well it's good to have for peace of mind, but honestly, the fuel is fixed depending on what jet size you are running, so it's not like you can really do anything about it. a vaccuum gauge would be a better investment (if the engine is damaged it will pull less vaccuum than it may have prior, so it can help to have that info). same with oil pressure (a spun bearing usually nets a drop in pressure)
Old Dec 12, 2006 | 02:04 AM
articzap's Avatar
My friend got his n2o kit today. I just want to make a quick list of everything else he might want to consider getting.
-bottle heater or blanket
-some kind of pressure gauge
-2 step colder plugs
-window switch
can you guys think of nething else?
Old Dec 12, 2006 | 08:41 AM
IonNinja's Avatar
make sure the bottle heater that he gets is regulated by bottle pressure and not temperature, it'll work better
other than that, thats the basics that he needs really.
Old Dec 12, 2006 | 08:57 AM
turbo06ss's Avatar
Originally Posted by IonNinja
KR = knock retard
I ran mine at .028 and picked up a little et and 2 mph
Old Dec 13, 2006 | 12:52 AM
cobalt25's Avatar
So who has nitrous on there 2.4
Old Dec 13, 2006 | 02:14 AM
articzap's Avatar
right now i dont know of ne1 that does....not to say there isn't but i havent read nething aobut it lately.
Old Dec 13, 2006 | 05:07 AM
Brandon97Z's Avatar
I know one guy had a zex kit but that was prolly 6 months ago since i have seen anything from him.
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
