Nitrous Oxide N20
Is Nitrous the easiest way?
Old Sep 19, 2006 | 09:07 PM
wdsoccer's Avatar
Well, like the title says. Is nitrous the easiest and cheapest way to get a good amount of hp in a 2.2l? if so what would i need to have a good nitrous setup, and whats the highest shot i can run. one of my friends said that i can run about 100 shot with stock internals. is that true?
Old Sep 19, 2006 | 09:17 PM
c0baltic's Avatar
i am running my 2.2 with the zex dry system.. it was an easy install.. but i wouldnt hit it with a 100 shot i am running a 50 shot every now and then.. but start off witrh a 25 shot.. but use the zex system it has a management box that helps..
-drew
Old Sep 19, 2006 | 09:28 PM
wdsoccer's Avatar
isnt a wet system better than dry
Old Sep 19, 2006 | 09:38 PM
wdsoccer's Avatar
is there only 1 person on this site that has nitrous in a 2.2l?
Old Sep 19, 2006 | 09:43 PM
REIGN SS's Avatar
Original Hayden Fanatic
yes you are correct, wet is better then dry... and i would graduate spray start at 25, then 35, next 50, and finally 75.. get a window switch(only spray within a certain RPM range at full throtle) & an arm/disarm switch, dont forget the perge kit... there are some threads that cover this, do an advanced search in the 2.2l specific threads
Old Sep 19, 2006 | 09:45 PM
REIGN SS's Avatar
check the nitrous specific section: https://www.cobaltss.net/forums//for...aysprune=&f=51 also
Old Sep 19, 2006 | 11:11 PM
celicacobalt's Avatar
can the cobalt even safely runa dry system? i though something with our fuel system needed us to run wet only.???
Old Sep 20, 2006 | 12:41 AM
REIGN SS's Avatar
to answer you ? yes as of now nitrous is the most affective power increaser
Old Sep 20, 2006 | 01:40 AM
nomoreavril's Avatar
yeah but also one of the most if not THE most dangerous way..lol
Old Sep 20, 2006 | 01:45 AM
REIGN SS's Avatar
..not dangous if you do it safely/correctly
Old Sep 20, 2006 | 03:08 AM
NJHK's Avatar
The thing is, when you're adding nitrous, you're throwing the a/f ratio off and making it run leaner. Running with a dry shot (no nitrous) is just making it more of a chance to detonate from a lean condition.
Adding fuel to the mixture is the safest thing to do.
Old Sep 20, 2006 | 10:44 AM
well i mean what does a returnless fuel system have to do with nitrous?
Old Sep 20, 2006 | 11:59 AM
SIMMONS 2.0's Avatar
i have the dynotune wet kit w/ a 75 shot setup....this is the cheapest way to get good gains...just make sure to get the proper gear to make it run correctly and safely...new plugs (colder), rpm switch and a heater are a good start...bottle pressure is going to be one of the main concerns...remember all the jetting calculations are done at a pecific bottle pressure...usually 900-950 psi...a heater will maintain that pressure when the bottle begins to empty...make sure to check your fuel pressure so that all jets are correct...i think we are around 40 psi fuel pressure i need to double check
Old Sep 25, 2006 | 04:01 PM
wdsoccer's Avatar
will Nitrous messs up my car in the long run?
Old Sep 25, 2006 | 04:28 PM
NJHK's Avatar
Anytype of extreme change to a motor that wasn't necessarily designed for the abuse you're giving it, will cause wear and tear...nitrous...boost....if you're changing something or doing something to your motor to make it perform very much out of the ordinary, this is the risk you run into.
Also, if the dealership was to see any lines from a nitrous setup, bye bye warranty.
Old Sep 25, 2006 | 05:25 PM
8cd03gro's Avatar
nitrous is always the "easiest way," but it may not be right for what you want. Nitrous is not for those that want more power all the time because spraying daily is a BAD IDEA. it is not cost effective and it is not a good idea for your motor. If you just want an occasional boost in power nitrous is the way to go, but if you want power all the time or most of the time, don't go nitrous, you will just end up getting rid of it and getting blown.
Old Sep 25, 2006 | 05:58 PM
NJHK's Avatar
Bingo!
Old Sep 25, 2006 | 06:52 PM
Halfcent's Avatar
I'm old school
Something I haven't seen mentioned here yet, Nitrous is also NOT street legal in most states.
Old Sep 25, 2006 | 06:53 PM
8cd03gro's Avatar
actually isn't it a federal law? i think if your nitrous is hooked up anywhere in the country you are done. not sure tho.
Old Sep 25, 2006 | 08:31 PM
NJHK's Avatar
It's not legal to carry. Reason being is cause it's an dangerous chemical that you're still messing with and you'd need a license to even carry it (well atleast in NJ). Even if you got a license to carry it, anytime a cop runs your plates, it will show up that you have a license to carry it and they'll want to check your car to see if you have any nitrous and if they see that you're in a "sports car" they'll want to see if it's hooked up (well actually, if the bottle is open).
It's more hassle to do it that way though.
It's probably the #1 reason I never got nitrous in the beginning...was paranoid of getting searched (which I did get my car searched once).
Old Sep 26, 2006 | 01:30 AM
c0baltic's Avatar
i am from jersey and i have NEVER heard that you need a license to carry it.. it is not legal to have on the street only to be used off road on the track... also ppl use nirouse in their paint ball guns
-drew
Old Sep 26, 2006 | 01:57 AM
NJHK's Avatar
-drew
Yeah but I'm sure they don't have a high quantity of nitrogen oxide like someone would have in their car.
And yes, you need a license to TRANSPORT chemicals.
Old Sep 26, 2006 | 02:02 AM
c0baltic's Avatar
yes to transport them that is a little diffrent than to actually purchase them, if that was the case then speed shops wouldnt sell it.. it's just like propane, you need a license to transport but not to buy
-drew
Old Sep 26, 2006 | 02:24 AM
NJHK's Avatar
-drew
We had a miscommunication
I was only referring to the transporting of nitrogen oxide, not the selling.
Old Sep 26, 2006 | 02:26 AM
c0baltic's Avatar
yes i know.. but still you dont need a license to go to a speed shop and buy n20.. i know it is illegal to transport it across state lines
-drew
