Nitrous Oxide N20
Is Nitrous the easiest way?
Old Sep 26, 2006 | 02:27 AM
NJHK's Avatar
Originally Posted by c0baltic
yes i know.. but still you dont need a license to go to a speed shop and buy n20.. i know it is illegal to transport it across state lines
-drew
Yes I know...I'm agreeing with you.
Old Sep 26, 2006 | 03:38 AM
rally's Avatar
In Illinois it is only illegal to have on the streets with an open bottle. So you can run it closed.
Well that was at least 2 years ago that way.
And as far as stock internals on 2.2 they can safely handle 75 hp shot
Old Sep 26, 2006 | 11:02 AM
8cd03gro's Avatar
i am from jersey and i have NEVER heard that you need a license to carry it.. it is not legal to have on the street only to be used off road on the track... also ppl use nirouse in their paint ball guns
-drew
people dont use nitrous in paint ball guns. so-called nitro tanks use compressed air, and other tanks use compressed c02. the nitro tanks fill up from a high powered air compressor and the c02 tanks fill up from a larger, c02 tank. Nitrous is not used.
Old Sep 26, 2006 | 05:41 PM
slowion2's Avatar
LOL you guys make me laugh sometimes.
Nitrous laws vary from state to state and even county to county. Keep that in mind. If you are just going out to the track, most officers will not bust your hump about it, **** they may be happy you're going to the track instead of the street anyway.
Fuel pressure is 60psi at the rail on the ecotec.
Nitrous is NOT any more dangerous than any other major power adder, you need to know what you're doing before you use it regularly or at all. 98% of the failures I've seen with nitrous have been user error. People need to stop believeing what they see on the silver screen so much.
I wouldn't run a dry system on these engines either.
Old Sep 26, 2006 | 05:43 PM
NJHK's Avatar
FACES OF NITROUS
Before:
After:
Old Sep 26, 2006 | 05:48 PM
slowion2's Avatar
lol well I do call it ******* juice
Old Sep 26, 2006 | 06:00 PM
NJHK's Avatar
"This just in, slowion likes juice in his *******...that is all"
Old Sep 26, 2006 | 06:05 PM
Strider_2001's Avatar
Does anyone have a list and links of EVERYTHING needed for asuccessfuly and safe n2o set-up
Old Sep 26, 2006 | 06:17 PM
zinner's Avatar
Moderator Alumni
-drew
I think they use nitrogen (N2) not nitrous.
Old Sep 26, 2006 | 06:20 PM
zinner's Avatar
Moderator Alumni
WTF people answer the question.
Here is my setup and I Think it's easy and safe.
ZEX 50-75 wet shot kit. It's TPS activated, and has built in pressure switches for fuel/nitrous pressure. It's an EASY 3 wire hook up so it's hard to screw up.
Then I have an MSD digital RPM switch so I don't spray over my rev limiter. This add's extra complexity to your wiring because you need to involve relays.
Last a blow down tube so if your bottle bursts the safety valve it leaves the car via the tube and doesn't fill the cabin/trunk we the laughing gas.
In all my nitrous setup has run me about 900 dollars with the zex kit and Tuner kit (bottle gauge, bottle heater, blow down tube and purge kit).
Take your time and learn how relays and switches work and it will be safe and fun. I have a wideband and if it was running lean I would know it.
You could also get a fuel pressure switch, but for the 50 shot I run, I opted against it.
Old Sep 26, 2006 | 06:23 PM
  #36
wdsoccer's Avatar
Thanks this will definatly help.
Old Sep 26, 2006 | 06:25 PM
  #37
zinner's Avatar
Moderator Alumni
You can't run a dry kit on a 2.2 ecotec because it doesn't have a MAF (or at least my ecotec 2.2 didn't) also I don't know if the fuel pressure is 60 psi on the 2.2.
Old Sep 26, 2006 | 06:29 PM
  #38
wdsoccer's Avatar
i am going to go with a wet kit
Old Sep 26, 2006 | 06:48 PM
  #39
8cd03gro's Avatar
the thing you have to be careful with when it comes to nitrous is heat. you should be fine witha 50 shot, but i wouldn't go to 75 stock, that could get hairy. With nitrous, you need to make sure you aren't the kind of person that will get carried away and spray twice a day. that's bad. If you just want an occasional boost go for it, just take all the safety precautions (i reccomend the zex racers kit if you go with a zex system<<<also reccomended) and you will be fine. Just don't think that you will be able to juice it all the time, that's when things get bad.
Old Sep 26, 2006 | 06:59 PM
  #40
slowion2's Avatar
I've been running 75 for a long time now and everything has been fine. ignition timing is modest enough to not be an issue.
you can spray multiple times a day, as long as you have sufficient bottle pressure, you're running the right octane fuel, etc. track nights I usually make 3-8 passes and there are 0 issues.
as i just stated, the fuel pressure on the 2.2 is 60 psi
the 2.2 in the cobalts does have a MAF, it's the 03-04 Ion's that don't, but even then it's not recommended to go above a 50 shot dry before the MAF (although as I said, I don't suggest a dry shot on the 2.2's at all)
Old Sep 27, 2006 | 04:21 AM
  #41
IonNinja's Avatar
why would you have to worry about heat with nitrous?
Old Sep 27, 2006 | 04:48 AM
  #42
NJHK's Avatar
I belive he means the temperature of the tank.
Old Sep 27, 2006 | 08:14 AM
  #43
8cd03gro's Avatar
i was about to go on a ramble about the heat and pressure from a nitrous system, but i decided most people probably already know why nitrous and any other power adder is dangerous for reliabilty, so i deleted it. I missed that first sentence lol. disregard it.
Old Sep 27, 2006 | 11:36 AM
  #44
slowion2's Avatar
haha yeah thats what I figured you were getting at.
Old Sep 27, 2006 | 03:50 PM
  #45
Fatalis's Avatar
Ive sprayed hundreds of times, no problems here. This is a rich 50 shot since I dont have a bottle heater.
And nitrous hasnt hurt my reliability at all. My car runs fine, I have an extra 50 horses when I need to, and the pressure hasnt bent any rods or melted any pistons with temps.
Its only dangerous for reliability if you **** it up.
Old Sep 27, 2006 | 04:28 PM
  #46
slowion2's Avatar
bingo
Old Sep 28, 2006 | 04:43 AM
  #47
IonNinja's Avatar
oh ok I was confused at first, I get it now.
I thought u were implying that nitrous raises engine temps or something...
Old Sep 28, 2006 | 10:53 AM
  #48
8cd03gro's Avatar
it does...no more than another power adder, but it will raise engine temps while you are spraying.
Old Sep 28, 2006 | 11:42 AM
  #49
slowion2's Avatar
actually if you're running a setup correctly you will decrease chamber temps and egts, but the increased speed of the engine and such can raise temps a little yeah
Old Sep 28, 2006 | 10:09 PM
  #50
wdsoccer's Avatar
so i just got back from the store and one of my friends said that if i was gonna run a wet nitrous setup that i have to upgrade my fuel system. he mentioned all this stuff but i dont know what he was talking about. can someone help me out?
