RWD conversion
Old Oct 28, 2006 | 05:24 PM
Loner05's Avatar
RWD conversion
Has anyone comtemplated on using the rear end from an solstice to make the balt RWD? I know I am going to get blasted for saying that but i figured what the hey.
Old Oct 28, 2006 | 05:31 PM
05BlackCobaltSS's Avatar
Yes, it's been talked about and basically ruled impossible, but with enough dough, anything can happen....
Old Oct 28, 2006 | 07:26 PM
Loner05's Avatar
what makes it pretty much impossible? is it placing the motor in longituginally(sp?) as oppose to transverse? Because the wheel base on the Solstice is only 8.4 in. shorter than the Cobalts and the rear track width is 2 in. wider on the Solstice. That could be fixed with a longer driveshaft and a deeper offset on the tires, unless you want to shorten the rear end. And of course any thing is possible with enough money except maybe men giving birth and growing wings to fly. lol.
Old Oct 28, 2006 | 07:37 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
If I remember correctly... you're gas tank will be in the way. But Like he said... Money cures all.
Old Oct 28, 2006 | 07:50 PM
Loner05's Avatar
there is a solution for that get a fuel cell. but of course that would require a bit more modification and can be tricky.
Old Oct 28, 2006 | 07:56 PM
moose's Avatar
yea it could be done......i have been experimenting with a awd setup...i think i am gonn attempt to do mine....its gonna be a bitch and take a while to do, but i think i may have all that i need to do it....me and couple good friends think we can do it, but first i gotta finish up on my pre blueprint sheet to get finished.....i will keep u guys informed when i get started...p e a c e
Old Oct 28, 2006 | 08:08 PM
NJHK's Avatar
Well first, you're talking about 2 different chassis, so you have to think about the measurements compared to both cars.
Then you have to consider cost of actually getting a full drivetrain from a vehicle that costs MSRP 20+ thousand dollars.
Also, you have to consider what are the actual benefits of doing this per cost.
For the most part, no one around here is either capable financially or skill wise to do something like this. I'd imagine it's an incredible amount of fabrication.
Old Oct 28, 2006 | 08:28 PM
tonio5555's Avatar
Doooooo ittttttttt.
It'll cost you thousands upon thousands, but you'd def get alot of CSS.net cred.
Old Oct 28, 2006 | 08:32 PM
Loner05's Avatar
they may be two different chasis. but i have read a post in the j-body.org site when i had a cavalier of a guy dropping in a 3400 v6 in his 3rd gen cavi. and that drivetrain came from a whole different chasis as well as that car costing more than a cavi. but given it was still a front wheel drive setup. and if i remember correctly there was not too much fabbing involved.
Old Oct 28, 2006 | 08:38 PM
NJHK's Avatar
Well, you're comparing a motor to another vehicle that IS fwd, compared to switching a motor & drivetrain to a car that ISN'T rwd.
Huge difference.
Old Oct 28, 2006 | 08:54 PM
HViper's Avatar
Retarded, for that kind of money you could buy a WAY FASTER CAR. Probally get you in a porsche that would out handle it to boot. I bought my Balt because it was the fastest one in my price range, and I got a GM discount so I had to by GM if I wanted to use it. In a couple of years when I make more money what should I do? Buy another cobalt and drop 50 grand in it or buy the Supercharged SS Camero they are talking about building? Ge, I don' know.... Do what you want, probaly be pretty badass, just saying I would not spend my money on it IMO. I think that the Camero has alot more potential than a homemade RWD cobalt. Once again this is just IMO.
Old Oct 28, 2006 | 08:57 PM
Jackalope's Avatar
Its easy! Get a wrecked Solstice and take its drive train out, then gut the Cobalt. Cut the floor to put the transmission and driveshaft tunnel in remove the fuel tank and put a fuel cell in the trunk. Then just swap in the Solstice stuff and TA DA! A RWD Cobalt!
True it is TONS of work but there you go!
Old Oct 28, 2006 | 09:01 PM
NJHK's Avatar
Also, if you run into any problems, it's all on you...no warranty and no one will probably fix any problems you run into along the way unless you found a specialist in the first place.
Old Oct 29, 2006 | 09:13 AM
Falcon Fixer's Avatar
A briefcase full of cash plus lots of time and and effort = One cool Cobalt !!
Old Oct 29, 2006 | 09:19 AM
joeworkstoohard's Avatar
i'd just wait for GM to release a hard top car based on that chassis.
Old Oct 29, 2006 | 09:27 AM
2K5SS/SC?'s Avatar
How about buying a by or soltice and getting a CF top made like the S2000 has available? The swapping to RWD would be a nightmare and definately not worth the money. I could see swapping the 2.0L Turbo engine into a Cobalt though as being feasible.
Old Oct 29, 2006 | 12:39 PM
Why don't you through in another set of tires in the middle, between the others... and make it 6 wheel drive? Just playing around. It's like they've all been saying... for the money and time it gonna take... it won't be worth it. When you finish making a RWD or AWD Cobalt... You probably could go out and buy an Evo X. Not saying you like them... but that is the point... it would be a waste of time & Money and you'll be a hell of a lot slower.
Old Oct 29, 2006 | 01:35 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
I was told to expect to spend $25,000 to go either rwd or awd. Not worth it, even for those of us who are crazy
Old Feb 26, 2008 | 01:24 PM
I just found this old thread and I laughed really hard when I read post #18.
You can likely see the humour and irony here.
Old Feb 26, 2008 | 01:27 PM
Rangerondubz's Avatar
I was like wtf did you just call yourself crazy? lol
Old Feb 26, 2008 | 01:31 PM
07SSCharged248's Avatar
haha bitch you crazy!!
Old Feb 26, 2008 | 01:52 PM
Let's be honest guys, would a sane or rational person do this???????
NO
Old Feb 26, 2008 | 01:54 PM
redlineblueline's Avatar
on a serious note instead of going ***** to the wall like vic did what about using a sky or soltice for a drive train platform
Old Feb 26, 2008 | 01:58 PM
That is totally doable with the gas tank likely being changed to a fuel cell.
The cost would be significantly cheaper but be prepared for a good sized labour bill to do the modifying for the rwd components.
Old Feb 26, 2008 | 01:59 PM
i was just curious using more readily availible components made for the engine instead of the huge amount of custom parts you have
