Ran the SS lastnight at Firebird.
Old Jul 16, 2005 | 03:19 PM
BullDog71ss's Avatar
Well, the car has 1,600 miles on the odo so I figured I'd give her a few runs. The heat lastnight was a miserable 102 degrees F at 10:00 PM..Ugh. Here are a few of the passes...
R/T... .659
60'... 2.647
330... 6.762
1/8... 10.050
MPH... 74.74
1000... 12.890
1/4... 15.272
MPH... 95.32
R/T... .796
60'... 2.375
330... 6.415
1/8... 9.681
MPH... 75.09
1000... 12.508
1/4... 14.882
MPH... 95.60
R/T... .277
60'... 2.411
330... 6.469
1/8... 9.754
MPH... 74.70
1000... 12.578
1/4... 14.974
MPH... 95.38
R/T... .376
60'... 2.556
330... 6.740
1/8... 10.053
MPH... 74.31
1000...12.905
1/4...15.293
MPH...95.13
R/T... .368
60'... 2.420
330... 6.545
1/8... 9.832
MPH... 74.74
1000...12.667
1/4... 15.043
MPH... 95.61
R/T... .071
60'... 2.693
330... 6.700
1/8... 9.965
MPH... 75.49
1000... 12.757
1/4... 15.124
MPH... 96.55
Lastnight was frustrating and satisfying at the same time. The heat was horrible, the track was worse (everyone running was pissed about track conditions and heat, some were a full second off normal times) and the car only wants to boost just a hair over 10 psi.
But with all of that, it still cut a 14.88, which gives me much hope for when it cools down.
Oh yeah, in stock form this is the worst sport car to run in the 1/4 mile ever produced, there is no such thing as traction in the Cobalt SS...just a whole lot of wheel hop.
Old Jul 16, 2005 | 03:27 PM
MarcS's Avatar
The Stig
Thoes are some great times for that heat and track condition, especially not even hitting full boost.
The Cobalt SS definately has no traction at the track lol, and it's torque-steer city.
With good enough conditions I bet you'd be in the low 14's.
Old Jul 16, 2005 | 03:30 PM
Ljavy17's Avatar
I also went to Moroso and they didnt let me run. They said i had to put a bottle to a radiator hose which is like in the air. So yeah i couldnt run man! Did they tell y anything aboiut your hose. or anything else that you couldnt qualify or u had to fix.
Old Jul 16, 2005 | 05:47 PM
SilverSS/SC's Avatar
Damn , lol .....my local track doesnt even inspect newer cars . Well unless they are obvious ALOT faster than stock .
I know what ya mean about launching this car . I know from expirience in mine that theres at least a lil over 1/2 second more in et "if" I could get the car off clean . Never have got full throttle in 1st gear ( or even close to ) yet and got it worked down from high 15's to 14.6-14.7 area Oddly I can lanch from a dig pretty good on the street , it spun and wheelhopped MUCH worse at the track . They need to let ya go from a roll at the strip , hehehe . 20 mph roll in first gear on the street puts the revs up around 4K , mash the go pedal and it just hooks and blast off like a little rocket ship
Old Jul 16, 2005 | 06:48 PM
I got almost NO wheel hop at the track, just a lot of wheel spin.
Watch out for wheel hop cause it will harm your drive train ...
Old Jul 17, 2005 | 12:10 PM
brianfcp's Avatar
wow, good times. i love firebird, too bad i have to take a personal day off work just to go there.
i noticed your reaction times quickened, but your 60ft took longer. "60' 2.693" , hehe, my 75hp honda accord had that 60' time. actually it was 2.695. not bad for 75 to the crank huh? I ran that accord at firebird as well... Im curious on how my 2.2 cobalt will do.
great job.
Old Jul 17, 2005 | 04:54 PM
mchat's Avatar
I get better traction (and times) at Speedworld. Come out on a Friday Night to Speedworld, the format is bracket racing, but after you loose you can run in the time only lane. The nice thing is that for bracket racing, the track is prepped. My best 60' on the stock tires at Firebird was a 2.3. My best 60' at Speedworld on the stockers was a 2.0. Difference of running 14.3-14.4 at Firebird and running 13.8-13.9 at Speedworld.
I plan on borrowing a set of slicks (if they'll fit) for this Friday nighat and see if I can get my SRT-4 into the 11's. Last night it ran a best of 12.2@118 w/ DOT cheaters. That was also the lowest trap speed of the night, highest was nearly 122mph.
Old Jul 21, 2005 | 01:23 AM
Mercury's Avatar
Yikes, that is why I am just going to wait until fall to run my car at the track. I don't want to see my car putting out 15 second quarter mile times....
Old Jul 22, 2005 | 07:05 PM
silverSS's Avatar
then u should mod it, cuz thats what most people run stock high 14's low 15's
Old Jul 27, 2005 | 04:58 PM
SS4ME's Avatar
I wouldn't worry about it. At your elevation, mid 14's may be possible with the right launch!
Old Jul 27, 2005 | 05:14 PM
glockglade's Avatar
Gripping
Hey last night was goofing around with the rubber and i found that if you want a good 60 time you need to do the following before your run let your car go all through first (big burnout)gear as you pull up to the line, then as you start i found the car launches best on stock rubber at around 1800 rpms maybe a little higher, anythinf over 2200 rpm you just spin your tires, remember a little wheelspin is the best if you are on stock rubbers(not a lot). Try running your car again after doing this and post your numbers!!!!!!!!!!!
Old Jul 27, 2005 | 07:14 PM
SS4ME's Avatar
They will not let you burnout with street tires at my local track! Best 60 ft. time was 2.16 that run I pulled a 14.707@96.1mph. I will do better when it cools off though. Plan on going back in late Sept. or early Oct. I will post my times afterward. I should have a grip on posting pics. by then. I will post the above time and other 14 second passes that I have run when I figure it out.
Old Aug 1, 2005 | 01:16 PM
AZESS's Avatar
Is anyone manufacturing aftermarket motor mounts for the SS/SC? I know they make a world of difference for wheel hop in a Type S. Of course, the stiffer mounts result in vibrations resembling a Harley Davidson at stop lights.
Old Aug 1, 2005 | 01:48 PM
mchat's Avatar
I made my own mounts for my SRT-4 and my Neon R/T. I bet I could make something for the Cobalt SS/SC, but would need to see one in person w/ the hood up, so I can study it a bit.
Old Aug 1, 2005 | 08:07 PM
phxSS's Avatar
mchat..hit me up, man. i have no prob meeting up with ya.
agentirons
Oct 16, 2015 02:11 AM
Tupp
Sep 30, 2015 08:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Dirtybutwhole
Sep 26, 2015 06:53 PM
Sean Cummings
Sep 11, 2015 09:35 PM
